Thread: Vibrations from wheels
    gloucesterhsire
    Default Vibrations from wheels
    when i brake i get juddering and vibrations from my wheels. it is getting worse there is a bit of vibration through the steering wheel at high speeds. i have had my brakes and discs checked and are ok. does anyone have any ideas?
    Bristol
    Default vibration
    You say you had brakes checked. it sounds to me that the discs are warped. I f you use aftermarket pads which are harder the oe pads , when you brake discs get realy hot and warp. I had it on my last car changed discs with oe discs and pads ok.
    Sounds like warped discs to me.
    When you say you've had them checked - exactly what was done? If it was just a visual examination then it's nigh on impossible to visually see a warp with the naked eye. It doesn't take much of a warp to cause the effect you're having and to measure it it needs to be done with a special tool - forgotten it's name.
    Suffolk
    If you have a vibration on your brake pedal when braking that's definitly the discs and if you change them make shure you do pads as well.If your steering wheel vibrates and woobles at high speed without braking you better go and balance the front wheels
    gloucesterhsire
    hi few more details. i dont think they did full check of discs with tool. i did have 18s on my car at 80 car vibrations would be bad so went back to 16s and not really notice able. the vibrations when i break are come from the ns wheel and its getting quite bad. roll on pay day lol
  1. vibrations
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 17:55
  2. Bad vibrations
    By tony tyre 1 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th November 2011, 07:25
  3. Vibrations?
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2011, 15:40
  4. Steering vibrations
    By Wilco in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2008, 09:16
  5. Vibrations!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2008, 11:39
