Thread: Interior Headlight Adjuster
    Apr 2008
    Burton on Trent
    Default Interior Headlight Adjuster
    I have a 53 reg Signum. On the dash there is a headlight adjuster that makes the lights move up or down. I tried it and it dosent work.
    Anyone know if this is easy to repair? or if it will be expensive.
    13 Post(s)
    Silly question, but were the headlights and ignition switched on at the time of you trying?
    Also, are you sure your not using the dash illumination by mistake?
    Regular Member s0501291's Avatar
    Warrington
    just an idea,, if the bulbs are not clipped in properly into their holders, the mechanism in the headlights may foul up..
    May 2008
    Tyneside
    Had this problem with mine. Turned out there is a nylon ball and socket joint on the adjuster motor that had become detached. Look inside the headlight and if the internal lampholders just flop about the motor needs re-attaching. If required remove motor (just a baynot fitting) attach actuator rod them refit motor. A bit fiddley but a quick cheap fix.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Try them in a quiet place and if the motors are working you will be able to hear them. As Big Dave headlights and ingition on. If no sound from motors, fuse???
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    or park up against a garage or wall at dark and try them then,if they dont move your beam up and down then you have problems
    Apr 2008
    Burton on Trent
    LOL yes I was in the car at the time. I was driving down a country lane thinking WTF I cant see a dam thing.
    I will have a look tomorrow in the daylight and see if I can actually see anything. I live in a very quiet culdisack so will be able to hear. Its so quiet round here that the cows and sheep in the field behind us keep me awake in the summer months when I leave the bedroom windows open.
    Will let you know later.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by simonturner1975 View Post
    Try cow tipping its fun
  1. Headlight adjuster motor going crazy
    By dittohead in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2011, 19:04
  2. Interior headlight switch with fog lights switches
    By merikiito in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th October 2008, 11:56
internal headlight adjuster
