Results 1 to 10 of 11
Thread: please help.......
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default please help.......
    move if required.
    car:
    2002 vectra c 2.2dti sxi
    mileage:
    104,000
    problem:
    after fitting two new rear tyres, the car is so noisy it makes your ears bleed....
    noise starts at about 25mph and gets worse especially at motorway speeds.
    the steering also feels really light sometimes kicking off bumps making the steering wheel do the same.
    Ive had a winter check done as well and they couldn't fault the car, but the problem still exists...
    please help - please ask any questions......thanks.
    Maybe the rear tyres are just noisy?
    Suffolk
    this is really bad - no car should sound like this....
    East Midlands
    Just have a quick check pal ,and verify they are not directional tyres that have been fitted the wrong way around,been known to happen b4.
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Id presume it would be the tyres what brand are they?
    Suffolk
    Quote Originally Posted by macdad View Post
    hi - just checked the tyres are fine.
    the noise and vibration comes through the front of the car.
    Suffolk
    Quote Originally Posted by Gregg View Post
    the new are kumho ku31 and the old were toyo's - both made the sound.
    it doesnt feel that the sound is coming from the rear though.
    Jun 2007
    Black Country
    whats the tread pattern like? I had winter sport tyres on until i swapped them just before christmas, and they were a lot noisier then my new ones, also recheck that the nuts are tight and that they didnt screw up the balancing
    Jun 2007
    Black Country
    in fact, swap the front and rears around, see if that makes any difference
    Quote Originally Posted by Judas View Post
    problem:
    Confused! At what point did the noise start to appear? - before the new rear tyres were fitted or already present before that?
