Results 1 to 10 of 11
Thread: Problem With Can-Bus System
    High Wycombe
    Default Problem With Can-Bus System
    I have a problem with my Vectra C Design 2.0 DTI. I would be driving when the car with the spanner light comes on and I instantly lose power.I try to keep the revs up but there is no acceleration and it dies.It takes several attempts to restart and I limp home. This started happening 2 years ago about once every six months. Last week it happened at least 6 times on a 5 mile journey. I went to a mechanic who put it on a machine which told him the problem lies within the can-bus syst He explained this could mean any one of a group of sensors. We unplugged the air flow meter and the car ran so I ordered one and fitted it but the problem was still there. I also replaced the diesel fuel filter and air filter. My mechanic recommends that I now replace the accelerator sensor.I am now driving with the airflow meter unplugged which lets the car run but limits the revs and also means the car/spanner light was on permanently and has now changed to the engine management light (I guess due to the time the other light was on). I am tearing my hair out and will try anything. Has anyone else had this problem and if so what was it. Thanks
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by parker1069 View Post
    did your mechanic use TECH II or a generic code fault reader... Suggest that you may need to find someone with a TECH II here..
    Ashington, Northumberland
    PM Plasma (Dean), he has Tech2, or Duncan, who has Vaux-com, which is the next best thing.
    Full Member Big Sig's Avatar
    Your mechanics equipment is not good enough. Get a vaux-com or main dealers tech 2 to read the fault codes. Otherwise your just wasting money.
    mid wales
    have the same on mine. unplugged temp sender switch on top of thermostat ,it revs ok now but smokes abit on tick over
    VIP-Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Check the throttle body.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Firstly, get it checked out by the right kit, as said above. and secondly, diesels don't have a throttle on the intake air.
    Trieste, Italy
    Engine : Y22DTR
    Quote Originally Posted by Ste View Post
    I'm not agree with you, on my dti I changed the throttle body a few months ago. I had the same problem. Loss of power and engine stop.
    This is the throttle body for Y20DTH and Y22DTR:
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is there a throttle (ie butterfly) inside that? Or is it a manifold type intake only?
    Trieste, Italy
    Engine : Y22DTR
    Oh... I don't look inside. The only thing I know is that my mechanics call it "throttle body", and also in the Tech2 the error code said something like "faulty throttle body", but I don't remember exactly... sorry!
    I wrote the errore code somewhere... I'll try to find it.
  1. DTUK multimap power system and red power system - opinions please :D
    By Princess D in forum Diesel Engine related
    Last Post: 13th December 2010, 01:03
  2. Signum Heating System Problem
    By Lotus_c_man in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2009, 14:04
  3. Cooling system performance problem
    By brianjamesreed in forum Engine & Drivetrain
    Last Post: 19th July 2009, 22:55
  4. Problem with exhaust system
    By mujju313 in forum Engine & Drivetrain
    Last Post: 1st April 2009, 21:23
