Results 1 to 3 of 3
Thread: Timing Belt
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Timing Belt
    Is the timing belt covered by Warranty if the vehicle as done the manufacturers recommended mileage for a change
    or
    is it only if the belt is broken and needs replacing?
    Regular Member cpt slow's Avatar
    In a house
    Im sure this was brought up before . As far as I'm aware , if the belt if broken and if a genuine Vauxhall one is broken before the designated time for replacement is due then yes .
    Can someone maybe clarify this ?
    Glasgow
    The timing belt is a serviceable item if it needs changed i.e hits the end of its lifespan while under warranty its like buying a pollen filter its upto you.
    IF it fails before its due to be changed then i would reckon it would be a warranty claim.
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 11:21
  3. Timing Belt
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 06:52
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. timing belt?
    By jaff in forum General Chat
    Last Post: 4th September 2008, 20:15
