Thread: Maf sensor
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default Maf sensor
    Just wondering if it is possible to clean the maf sensor and best product to do it with if so.Plus how carefull should I be.
    Regular Member Avenged's Avatar
    Liverpool
    Don't know the best stuff to use mate... but if you do clean it....
    be very carefull!!!!!!!!!!
    Isopropyl Alcohol (Isopropanol) - you can get it from chemists or a spray can from Maplin. Carefully spray it from a distance or soak it in some that you've sprayed/put in a jar etc. and let it sit for a bit. Take out and give it gentle waving in the air to evaporate off all the excess.
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    is the MAF removed easily excuse my ignorance
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    id use carb cleaner or similar then blow it out but would only do it if it playing up if not leave it alone could cost you a fortune if not
    Quote Originally Posted by BIG NEIL View Post
    Yep, you just disconnect the plug and loosen the jubilee clips clamping the section of pipe that comes from the air filter into the section carrying the MAF and remove.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
