Thread: How do i remove oe front splitter
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Default How do i remove oe front splitter
    As some of you might know I have bought a VXR front splitter off Swainey which did not come with instructions so I need a little help on a few things.
    How do in remove the original small black splitter as found on a Facelift SRI.
    Are there any DO's or DONT's on fitting the VXR splitter. I have bought some spoiler adhesive which is the same type as used on my rear spoilers and I have painted it ready to fit.
    As said above I have no instructions so all comments are very much appreciated.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    iirc then the lower rubber type jobbie is just clipped in and also held with a few little push type rivet's.......just look under the front of the car as it is 2 pieces, joining in the midle so there will be a rivit there for starter's
    as for fitting, plenty of stuff on the spoiler and use masking tape to hold it in place while it goes off
    hth
    Midlands Mod Shop - NFFC.
    May 2007
    WINSFORD
    Cheers Rich, I dont want to wreck it just incase. Any info on the VXR splitter ?
    Regular Member Lump's Avatar
    coventry
    rub some very cherry on it mate
    May 2007
    WINSFORD
    Hows your HOT wax
    Trim : Get a
    i made an edit to my first post matey, i did matt's irmy one and it was a pain in the ar53 to say the least....
    try it first (dry run) and use a bit of tape in various places to give you a marker point of the hight, apply the bonding to the splitter and get someone to give you a hand in placing it on the bumper.....then tape down firmly and clean any smudges asap....should take a few hours to go off in a warm room....
    May 2007
    WINSFORD
    I noticed that there are are drill holes in the parts that wrap round into the wheel arch area which I suppose will take the lower wheel arch liner screws, if you know what I mean
  1. Quickest way to remove front/rear splitter
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 16:58
  2. How to remove front bumper?
    By GSiFan in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2009, 22:56
  3. Fitting XP front splitter - Should I remove the black lip spoiler?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2009, 11:16
  4. remove front hub!
    By 2MUCHGAIN in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2009, 20:06
  5. How to remove front cupholder?
    By FLi in forum Bodywork & Interior
    Last Post: 10th January 2008, 21:17
vectra c splitter removal
front splitter
how to remove splitter on vectra c
insignia front lip fitting instructions
vauxhall vectra c club front splitter
fit front xp splitter
how to remove the splitter off a vxr vectra c
vectra c splitter
