Thread: 150 1.9 facelift power problem
    Regular Member mel's Avatar
    tayside
    Default 150 1.9 facelift power problem
    help please....... my 150 cdti facelift has no power until the turbo kicks in at about 2300rpm
    once it is above 2300 revs, it goes no problem 70/80mph
    there is no shuddering.....just flat until revs kick in....
    the light came on for about 5mins when slow around town, but when i got out on the open road, it cleared...
    EGR?????????
    Here, there and every where!
    Probably m8
    Chester
    Sounds just like mine when it went. Light came on just once then zero to head for the hills when the turbo kicked in. The fuel consumption went up too.
    tayside
    Do you think it will be F@&KED or will a clean out do????????????????
    Chester
    Some of the guys have cleaned theirs successfully . Mine was under warranty so I didn't. There are a few threads about how to clean it I think.
    Here's one if it does turn out to be the EGR valve:
    http://www.vectra-c.com/forum/showth...&highlight=egr
    tayside
    had a look for a thread bt could only find one for a 2.2dti.....
    Will get it off and give it a clean.....if not then will need to buy a new one!!!!!!!!!!!
    out of warranty by two months!!!!!!!!!!!!!!!!!!!!
    Any idea on price??????
    tayside
    cheers
    Oct 2007
    Gloucester
    Mine cost about £160 at the stealers to buy and fit.
    Solved the problem - drives like new again.
  1. power steering problem
    By pud wayman in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2012, 13:47
  2. power steering problem?
    By bigbrox in forum Engine & Drivetrain
    Last Post: 6th May 2012, 19:33
  3. Power Steering Problem
    By marcel1 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd August 2008, 15:39
  4. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
  5. Help 150CDTI - Power problem
    By bennyk in forum Engine & Drivetrain
    Last Post: 26th July 2007, 14:21
