Thread: Twaang!!!!
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Default Twaang!!!!
    Oh Pants!!
    Heard this a couple of times now when accelerating hard over bad roads. Seems to be coming from front left passenger side.
    Could it be the springs?
    Regular Member JonV6's Avatar
    Cardiff
    I get this all the time when manouvering at low speed or going over bumpy roads etc...
    Having read lots of threads about suspension noise I believe it's caused by the springs moving in the lower cup....
    VX did a mod to help solve the problem but not sure when, mine's an 05MY and it has the mod but still twangs...
    I cleaned all the grit and **** out of the lower cups on mine and packed them with grease which made a big difference although the grease itself is now attracting more crud!!!
    It might be worth checking your springs to be sure none of them have snapped but ouside that, I've just learned to live with it!
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Mine does this now and its over bumps and accelerating and braking hard
    surrey
    Trim : SRI
    Year : 53
    Strange one for sure!?
    Gonna check the rad mounts as well today to see if there is any play in them.
    Mar 2007
    Finland
    After I did this, twangs haven't been an issue anymore.
    surrey
    Trim : SRI
    Year : 53
    Thans for all the replys.
    Checked the rad mounts and they look fine, just a little give. Thansk Jay-C
    I will give that a try.
    Jan 2006
    Dalriada
    i get this alot too especially on rougher road's. I am going to give jay c's suggestion a go, need to order a couple of new sleeve's for the spring's to sit on i was going to replace the drop link's and front arb bush's but will try the quick fix first
