Thread: Cruise Control
    wigan
    Default Cruise Control
    I have a bit of a cruise control problem. Some times lately when I'm trying to accelerate with the button the cruise shuts off. any ideas cos i love my cruise control...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Dirty connectors in the stalk.
    Try rapidly switching up / down and maybe a spray of electrical contact cleaner in there too. Mine did it, but on decel button and this method cured it. I think it is the grease inside the switch gets on the contacts.
    wigan
    thanks, i'll give it a go
    HULL
    Default Cruise control problem ,not working now
    Hi
    I have had anintermittant problem with my cruise control for the last couple of weeks , it would work fine , then a sometime later stop working , i`d go back to the car and it would work again ..now its not been working for 3 days
    .Any one got any ideas , the buttons feel ok and dont seem to be sticking.
    ..all help would be appreciated as i am selling it in a couple of weeks to get an SRI CDTI
    Many thanks in Advance
    11 Post(s)
    Usual cause is the clutch/brake pedal switches, which in turn is caused by a weak spring not returning the pedal to the fully up position and engaging them.
    http://www.vectra-c.com/forum/showthread.php?t=33621
    Regular Member MrT's Avatar
    Near Durham
    Mine's just started to develop an annoying fault that seems to be getting worse.
    Set cruise, no problem - it's normally been very reliable - could and have set it at one end of the M1 and gone halfway down with no issues, indicating to change lanes, using the jog up/down okay etc
    Now, in the past couple of weeks, it's developed a fault where the slightest touch of the indicator stalk cancels the cruise - and I've double-triple checked that I'm not touching the cancel button, and have tried the brake pedal trick etc.
    Tonight on the A1 I changed lanes, indicating using the short '3-flash then off' feature, and almost as soon as it was finished, the cruise died - not even touching the stalk at the time.
    Is this a dicky switch? Or is it something more like the CIM? I've noticed that the car is more sensitive to cancelling indicators of late, and even though it has always been a bit keen, it's now cancelling them as I start to turn into corners.
    It's the same stalk, but other than that are these two glitches in any way connected?
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
