Results 1 to 10 of 14
Thread: Help - CDti 150 Juddery!
    wigan
    Default Help - CDti 150 Juddery!
    I've had my diesel sri for 6 months now, now I don't know if it's me getting used to the car but it deffinatle seems slower than when i first got it. Also, when idleing, if i slowly push the acceleration pedel in and stop ar 1500 rpm it feeds really juddery. also recently i've found that if i slow accelerate in 2nd, when it gets to just over 2000 rpm the cars seems to missfire?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    sounds a lot like injector no.3 wiring mate - known fault:
    http://www.vectra-c.com/forum/showth...t=62925&page=4
    also wouldnt hurt to clean the EGR valve...
    HTH
    wigan
    i've done the egr already. thanks for the reply
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by phildjohnson View Post
    np - would certainly look at the injector no.3 issue then...
    Just had mine done - with ECU update and the difference is amazing, and mine was only just starting to judder when cold in the morning when cold on idle..
    wigan
    forgot to say. Paid Vx to check with Tek 2..... no faults recorded
    Middlesex
    Trim : SRI
    Mileage : 100k
    nope - mine neither.. no fault codes at all, but it was the first thing that my stealer said needed to be done... very common..
    wigan
    was yours under warranty. mind is out now. do you know how much it costs to get done
    Middlesex
    Trim : SRI
    Mileage : 100k
    thats the trouble - no mine wasnt under warrenty - 2005...
    Expect 2.5 hrs labour - plus about 15 quid for the part... if you do put it in make sure that they incl a ECU update too... mine was quite a way out aparently and thats with full dealer history... Aperently a service does not incl a ECU software update.. thats only performed when there is a reported problem!!
    Middlesex
    Trim : SRI
    Mileage : 100k
    ..... also note that they will only change no.3 lead under the TIS artical... thats the only one that causes an issue - something to do with the hot air flow or something
    wigan
    thanks mate
  1. juddery while driving?
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 24th March 2011, 20:23
  2. Juddery Clutch
    By spatch in forum Engine & Drivetrain
    Last Post: 14th January 2010, 12:36
  3. juddery sun roof
    By beakster in forum Bodywork & Interior
    Last Post: 24th October 2009, 12:27
  4. Juddery fault update!!
    By bigpaw35 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st August 2009, 20:18
  5. Steering is a little heavy and juddery
    By freshprince in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2008, 11:57
