Results 1 to 10 of 19
Thread: Wing-Mirrors.
    Plymouth
    Default Wing-Mirrors.
    Ok one of the things on the snagging list for when I bought my
    2.0 DTi 54 Plate Vec
    was the wingmirros.
    the left mirror moves ok on its own.... but when i got to move the right one (drivers side) it moves the passenger side at the same time..
    Well the salesman sent it off to their workshop to get sorted....... and the technician came back and said thats normal for Vectras.....
    Is this correct.... or am i being fed a load of trollop??
    Dan
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    That is not Correct at all there well trying to have you off.
    They should both move seperate
    Ask him were did he learn that the stupid Pr1ck
    Plymouth
    Quote Originally Posted by Sean-2.2Direct View Post
    Thought so...... i just think that the short circuit is a pain in the ass to find..
    if i get a few more replies saying the same i will phone them back up
    Apr 2008
    Liverpool
    Tell that lazy son of a ***** to full his finger out of his A$$ hole and get to work finding the problem there is 2 little buttons on the door panel the left one activates the left mirror and the right the right mirror
    Quote Originally Posted by Diet1985 View Post
    He's right.
    The early models moved each mirror separately when you pushed in the relevant button, but then they changed it to a feature that supposedly makes it more convenient.
    What you do is push in the driver's side button and adjust the driver's mirror to suit - ignoring what the passenger mirror is doing. Then push in the passenger side button and adjust that accordingly (the driver's side mirror won't be moving when you do that).
    Then the supposed advantage of the new feature is that if you then push the driver's side button back in again and adjust the mirrors (say pushing on the left rocker switch) you'll see both mirrors move inwards. It's meant to make it quicker to adjust the mirrors when somebody else drives the car as both mirrors move at the same time.
    On my 03 I had the independent movement but this then changed to the new feature when I changed a door module when I did my folding mirrors mod. At first I thought but then you quickly get used to it. I don't really need it on mine anyway as I have memory seats.
    Plymouth
    Omg I cant believe they thought this was a good idea!
    Thanks Duncan for letting me know that its normal on newer models etc.
    No probs - it's weird until you get used to it which doesn't take long.
    How many slices of humble pie would you like cut?
    Regular Member chrisf70's Avatar
    Mar 2007
    Cambridgeshire
    I've come from driving VWs and they all do that, so it hasn't been too much of a shock.
    Don't all Vectra Cs/Signums do it then?
    No, on the earlier ones (up to around 04 I think) the mirrors worked independently i.e. each switch only moved that specific mirror.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    it can still be turned off in the DDM and PDM acording to plasma
  1. wing mirrors!!
    By ross4705 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 22:47
  2. Wing mirrors
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 23:01
  3. Wing mirrors
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2008, 08:55
  4. wing mirrors
    By simon5800 in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2007, 01:52
