Matt chrome bottom spoke (pre facelift sri 3 spoke wheel)
93179295 (£9+vat)
I bought this item from the dealers and it doesn't fit my steering wheel
The part number matches the above part number. Anybody else had this issue?
93179295 (£9+vat)
well i got given one and it does not fit proply, the holes line up and the bolt goes in but it sticks up at the bottom and dont look right...i will post a pic of it later, i will go and get it from the garage b4 we go shopping later![]()
Things line up (reasonably) but the plastic cone that the screw fits into is too long which means that the cover sits too high. I'm going to take it back.
here she is, no good for my sxi wheel![]()
That's the one i got too. And it won't fit my SRI wheel either.
I could but when i buy this for £13-14 i expect it to be ready made to fit my car. It doens't appear to sit right even if i where to cut it back a little bit.Could you not trim a bit off the plastic cone that the screw fits into?
Im sure someone else fitted one here a while ago and that didnt sit right either. Im trying to find the post but cant remember the thread title. If I find it, will post up!
If it's the one for the Astra steering wheels, you have to cut it down to fit.
I bought the granite / charcoal metallic version for mine & had to cut / file it down to match the shape of the original.
The piece for the retaining screw was also cut down to the same length as the original.
Just found the thread that shows mine:
http://www.vectra-c.com/forum/showpo...87&postcount=1
