Thread: Front bang/knock noise on turning wheel
    Ripon, North Yorkshire
    Default Front bang/knock noise on turning wheel
    My problem has slowly developed. It used to be only on full lock turns but now when parked I can get this to perform by jiggling the steering wheel on a good surface. It bangs on change of direction of the steering wheel.
    It sounds like bottom ball joint or could it be something to do with the steering rack?
    I would be grateful for some input.
    N
    May 2008
    Tyneside
    Have you checked the pinch bolts on the universal joint at the bottom of the steering column. This happened to my sons corsa, kept coming loose until I put some loctite on the bolt.
    Thanks for your reply but the knock/bang is heavier and comes from both sides. I suspect lower ball joint or something else. Its only when there is alot of stress on changing turning direction that it bangs.
    Suffolk
    Have you checked if is the springs? Do they have fitted the rubber sleves on the spring? If it is a ball joint all you have to do to check it is lift the car and with the wheels on the air hold the wheel with both hands and rock it hard up and down and side to side, if there is play on the wheel ask someone to get underneath and see from where is coming from.
  1. Knocking Noise When Turning Wheel
    By sligo_eire in forum Troubleshooting
    Last Post: 2nd June 2014, 05:58
  2. Noise from F/O/S wheel when turning left
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 23:24
  3. near side front wheel knock
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2010, 07:52
  4. Clonking noise heard when turning the steering wheel
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 15th January 2010, 02:40
  5. Judder / Bang / Knock - When cold
    By bobby_rstevens in forum Engine & Drivetrain
    Last Post: 6th May 2008, 14:12
