Thread: How do you disconnect the window switches.
    NI
    confused How do you disconnect the window switches.
    My Signum (Design) driver's door electric window switch has gone dodgy on the right-down contact. I tried to get it out to try to clean the contact but how on earth do you disconnect that connector on the back? Didn't want to completely wreck it because all other contact work fine, I just couldn't work out how to get it free so I could work on it with more than 3" working space - didn't help that my hand's were getting frozen trying to work on it.
    Sunny Dartmoor
    Just pull the little connector out,its not difficult,you wont brake anything,hth......
    Feb 2007
    Glasgow
    The connector has a locking mechanism. You have to release it and push it to one side... then the connector just pulls out.
    Easier to do than describe
    NI
    It looked and felt like it was "locked" in some some way, I just couldn't work it out in the few minutes I was prepared to work outside on it. I've the garage cleared so will be able to work on it a bit more easily tonight. Any more details, e.g. do you push anything inwards, pull up/sideways etc?
    Anyone stripped one of these switches before to clean the contacts? Am into electronics so have contact cleaner etc, so that doesn't worry me but anyone done this and aware of af stupid things like springs that pop out when you open up the switch itself?
    Many thanks.
    Feb 2007
    Glasgow
    It's fairly obvious when you look at it how to release the lock. There's a little clip that swings to one side, then the connector can pull out.
    Once you get the switch out, there's two small screws to undo, then unclip the backplate. Hold it with the switches facing down and nothing will fall out. There are no springs, only a couple of plastic "pushrods".
    When you take the back off, you will be able to lift out the PCB and the switch membrane.
    Give everything a clean and put it back together again.
    May 2008
    Tyneside
    When my switch didn't work, I just removed it and squirted switch cleaner / lubricant into the cracks next to the rockers at the same time operating the switch firmly. This worked without having to dismantle the switch. HTH
  1. Window switches
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 17:30
  2. Window switches
    By VeccyMike in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2012, 00:42
  3. Window switches
    By coldo in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2012, 07:39
  4. window switches
    By elite lee in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2011, 11:38
  5. Door Switches Disconnect wiring
    By NealM in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2008, 21:42
how to unplug a vectra window switch www.vectra-c.com
how to unplug drivers electric window swich vectra c
how to unplug vauxhall signum drivers window switch
