Thread: cruise control
    Regular Member swainey's Avatar
    Newtown Powys
    Default cruise control
    hi can anyone answer this
    we were off to manchester on friday nite when it was -4 when i went to put my cruise control on and nothin happened??????????????????
    after several miles i tryed it again and still nothin???????????
    after about half an hour the temp had changed to -1 so i tryed it again and it worked no problem does anyone know if cruise control only work above certain temps
    thanks swainey
    Maida Vale
    I assume you'd pressed the brake pedal between the time you started your journey and trying to activate the cruise control?
    Quote Originally Posted by Thomas1 View Post
    i forgot when I left a service station once, took me ages to remember that
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    i had same type thing Ste on a journey to cornwall last year , strange but it just cured its self
    Newtown Powys
    yes i did 40 miles on country lanes before i got to the duel carriage way
    Mar 2007
    Dunstable, Bedfordshire
    I've started having the same problem with my 2005 veccy ....it wont even switch on at all now...I've tried pulling up the clutch and engaging. but nothing...people are saying its the cruise control stalk? is that the stalk behind the steering wheel or in the engine somewhere?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The stalk is the thing sticking out from the steering cowl - ie the lever that you move to get the indicators and main beam to work, with buttons on the end. These buttons sometimes degrade over time - the switch contacts get dirty / greasy. Mine stopped functioning correctly, so some rapid switching cleaned the contacts and it now works perfectly.
    Regular Member oldgit21's Avatar
    South
    AAMOI How do you remove the signal turning stalk, a case of removing the cowlings and couple of screws underneath perhaps. ? Just wondered as I get occasional squeek noise when moving indicator stalk. May just pop it back into dealer when passing.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by oldgit21 View Post
    get some mig wire or similar,if you look under the lever there is a groove,slide the wire down the groove and you should feel some resistance,gently pull the lever and it should pop out,dont yank it out as sugested somewhere on this site
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
