Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: What repairs have you had done?
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Default What repairs have you had done?
    I was thinking earlier today what might need be repaired on my Vectra this year, as I have just replaced the top rear control arms on New Years eve and thought hey thread time!
    So please list:- model, mileage, year of car and a list of repairs both in and out of warranty – cut and paste previous break fixes so that there is a running list
    So to start:-
    Vectra 2.0T 2004 - 30,000
    Rad mounts
    Exhaust mounts
    Air con condenser dryer - leak of fluid but still working
    Upper rear control arms
    Jun 2007
    Black Country
    Signum 2004 Design
    3.0V6 Diesel
    nearly 90,000
    I had a fuse blow
    and Ive replaced Discs all round
    Signum 2003 Design
    3.0V6 Diesel
    Steering column UJ (covered)
    Rear screen (covered)
    Rad mounts (covered)
    Front springs @64k (paid for)
    Boost pressure sensor (covered)
    Map sensor (covered)
    Climate control panel (covered)
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    2004 2.2 Petrol SRi with 50k on the clock
    Air con condenser
    Engine ECU
    Cylinder Head
    Oil Scraper rings
    Hole new Engine
    Power Steering Pump
    All under Warranty before 30k, about £8000 of work!
    1 Front Bearing/Hub £65 off ebay, £40 to fit @45k
    Only MOT fail was Stock indicator bulbs weren't orange enough LOL @ 30k
    Hydraulic Lifters need doing now to add to the list.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    2005 120 cdti vectra sxi. 53k miles.
    top oil seal replaced (warranty)
    2 x DMF's one due to oil staining from an oil leak and the other for a vibration through the clutch pedal (warranty)
    rear hub assembly replaced due to thread's stripping replacing rear shock absorber (warranty)
    alternator (warranty)
    rad mount's (warranty)
    driver's seat base (warranty)
    egr valve (warranty)
    rear disk's and pad's (warranty)
    cim module (warranty)
    new key (warranty)
    2 ECU upgrade's (warranty)
    think that's it, but most of them were because i am finicky and the slighest thing that felt weird and it was in.....
    Midlands Mod Shop - NFFC.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    2003 2.0 dti 150k
    Drop links
    Anti roll bar bushes front/rear
    Springs
    Shocks
    Top strut mount
    Rear arms
    surrey
    Trim : SRI
    Year : 53
    Update
    Rad mounts
    Exhaust mounts
    Front drop links and front bushes
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    2002 Vectra 2.0 DTI elite 123500 miles
    Front N/s roadwheel sensor
    wiper linkage
    4x injectors
    4x dash vents
    dash climate unit
    4x springs
    Airflow meter
    bolster on drivers seat replaced with actual leather (not vinyl)
    that damn ashtray in the back permenatly shut
    Regular Member bgm46's Avatar
    South Queensferry
    1.9 Cdti Estate 2004 - 74000
    Bush at top of front suspension
    Rear Wheel Bearing
    Anti Roll Bar Bushes
    Injector wiring loom mod
    Drop links (Will be done shortly, sitting in back of the car at the mo)
    Front Springs (Warranty)
    Air Con Compressor (Warranty)
    Regular Member garvey's Avatar
    Co Durham
    Engine's
    gearbox
    steering Rack
    altinater
    front and rear shockers lost count how many
    front and rear springs " " " "
    strut tops both sides
    front and rear anti roll bar bushes
    drop links
    rear anti roll bar link
    front pasenger wheel bearing
    both rear calipers
    fan belt tensioners
    boost hoses lost count
    oil cooler
    3 batteries
    thats all i can think at mo
    radio ccr2006
  1. Snowflake repairs
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2011, 21:47
  2. some repairs!
    By redross555 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 02:20
  3. repairs!!
    By farley2708 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 22:14
  4. Repairs
    By Andy M in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2006, 08:19
  5. PDA Repairs...
    By C19_CJB in forum General Chat
    Last Post: 22nd March 2006, 17:11
