Results 1 to 10 of 17
Thread: Pc to Tv screen resolution
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Pc to Tv screen resolution
    just about to hook up my new tv to the pc.. as theres nowt on tv to watch tonight so got a few episodes of dexter season 3 to watch..
    now just wondering what the ideal resolution is to use?..
    when i tried it with my samsung it took several attempts of switching between the monitor and the tv to get the picture right..
    and now \i cant remember what settings i used..
    any idea what the ideal resolution to change the screen size to?..
    ta in advance!!
    Belfast
    What TV is it, how are you hooking it up, etc? NEED INPOOOT! as Jonny 5 would say.
    Oct 2006
    Wellingborough
    you want to pick the native resolution of your display. if its full hd then 1920x1080, or a "hd ready" set is probably 1360x768.
    its a samsung 1080i plasma.. as for the connection, its using the blue pc plug thingie that screws into the back of the tv/monitor
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Dexter... good call... Great series. Didn't know it was back on TV??
    series 2 has finished now over on sky.. series 3 has been shown in America and is available on streaming etc.. (pm me if you want link).. season 4 is out very very soon!!
    Quote Originally Posted by Dwabo View Post
    I'd start on 1024 x 768 to begin with and work your way up from there. Make sure the refresh rate is set low initially and then wortk up to as high as it allows while showing a stable pic.
    Didn't we cover this all in another thread and I got you all working?, with the problem being the res you were using?
    ah yep..but changed the tv now..and i had to keep starting and restarting the computer and swapping between the two.. just wondered if ther is an easier way other than manually keep swapping it over..
    dont i just need to change the display settings though the control panel?
    and if so, what does the resolution sizes mean?>..
    do i need to use size of 1280*1024 or go for smaller than that?.. what do the sizes actually mean?
    Ah right.
    Yep, that's all you do - or right click on the desktop and chose properties if you're on XP.
    On the PC it's simply how many pixels wide by high it sends the image to the display and in terms of the display/TV it's native/max resolution is what you can send to it and still display properly.
    Using the same (physical) display, a higher resolution setting allow more information to be shown in the same area is the basic way of describing it.
    You just have to make sure you're sending a resolution, and regresh rate, to the TV that it can handle. Look at the TV's specs to find that info.
    Regular Member sy_uk's Avatar
    Newcastle
    If you're streaming over the net i highly doubt the quality of the video stream will be good enough to view via your tv in fullscreen
  1. new screen now screen wiper problem
    By kenno31 in forum Bodywork & Interior
    Last Post: 18th February 2012, 12:34
  2. HELP !!!! vec-c website resolution problems
    By bertbuckie1 in forum General Chat
    Last Post: 6th May 2009, 22:07
  3. New Years Resolution
    By VauxVeteran in forum General Chat
    Last Post: 30th December 2006, 20:12
