Thread: 2004 3.2 V6 Vectra misses auto gear change
    Australia
    Default 2004 3.2 V6 Vectra misses auto gear change
    The problem we have is that our Vectra intermittently briefly misses the auto gear change from 2nd to 3rd and slips into neutral. It only lasts for less than a second and then it finds third gear. It also can be a bit rough on the change down from 3rd to 2nd.
    It has happened every now and then since we bought the car and mechanics have never been able to replicate the fault, though that's probably because they wouldn't be accelerating too hard on the test drive when it changes from 2nd to 3rd so they don't break the speed limit.
    Does anyone have any idea what might cause this?
    Jul 2006
    There's a known fault with early auto boxes - basically the box cracks where it meets the oil cooler and you end up with oil in the ATF. Common symptoms seem to have been similar to yours, with dodgy gear changes and then loss of some gears as the problem develops.
    If you speak to your local stealer they should be able to tell you if your box is within the problem batch.
    Australia
    Thanks for the quick reply! I'm taking it in in a few days so I'll mention it and see how I go.
    H-Budapest
    Hi,
    I have the same problem with my '03 Signum. Do you have any resolution yet?
    BR
    Check the ATF to see if its got water mixed in with it. If its red your ok, if its pink then have a search on here
  1. gear lever change for auto vec c v6
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 18:32
  2. 2004 vectra 3.0 v6 diesel automatic gear box
    By vectra 3.0v6 sri in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 23:05
  3. Vectra C - 1.8 2004 model - Cambelt change
    By Harry Hammer in forum Vectra C / Signum Troubleshooting
    Last Post: 26th June 2010, 17:59
  4. Auto headlights on 2004 vectra
    By gazturbo in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2010, 00:02
  5. 2004 Vectra Elite Auto 3.0V6 CDTI
    By Woodenman in forum Cars for sale
    Last Post: 20th September 2008, 15:22
vectra c 3.2 v6 automatic slips slightly between 2nd and 3rd gear
vevtra c 3.2 v6 slips between gears
vectra c 3.2 v6 auto slips
