Results 1 to 3 of 3
Thread: headunit on Vectra C independently of ignition ???
    Feb 2007
    Wiltshire
    confused headunit on Vectra C independently of ignition ???
    Hi everyone !
    Recently I installed an Alpine headunit on my vectra C (04 plate) using PC99-ALP, Alpine Adaptor Lead (nexxia). It's working alright with the key in. Is there any way to connect a headunit to run independently of ignition (key out). ????
    Thanks !
    Blantyre
    Think you can join the red and yellow wires together..... or look for a perm live
    But why would you want it that way ??
    Feb 2007
    Wiltshire
    well... it's that annoying beep beep sound whenever you turn the engine off leave the key in and open the door. When you clean your car for instance, you want to listen to music but you can't unless you turn the ignition on leave the key in...
    Thanks, I'll give it a try.
  1. Does the vectra 3.2 have ignition leads?
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2012, 11:30
  2. Vectra C (early 04) Ignition Key Problem
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 21:19
  3. 2007 Vectra Ignition Coil Help
    By heathersonline in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2011, 09:09
  4. Vectra 3.2 05 Gsi clicking noise when ignition turned on/off
    By bignew in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 19:36
  5. vectra 2.0 dti ignition
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 26th February 2009, 23:20
vectra c 04 head unit
