Results 1 to 10 of 11
Thread: Clunking from Front Passenger Side
    Regular Member nick-v2.2's Avatar
    Nottingham
    Default Clunking from Front Passenger Side
    Good Afternoon All,
    I have been experiencing a problem with my facelift vectra c.
    Goin over speed bumps theres a like crunching sound. Also steering was very wavy, loose.
    Took it to a garage and they were unable to find a fix for all.
    They said the bushes were worn on the wishbones so both have been replaced. £240 :-(
    I have also had both the rear trailing arms replaced £160 but that was last november
    Both the drop links and the ARB bushes have been checked and apparently they are fine. For the cost of £10 for ARB bushes i was gonna ask them to just replace them anyway.
    The steering has improved since the wishbones have been fitted.
    The crunch/clunking sound is not so loud now, but is still there.
    The garage seem to think its the shocks. Unfortunately i have no idea. My local garages arent much use but this is about the only one i trust.
    I dont really have time to take it anywhere else. I know there supplier is Parkers.
    Any ideas of anything else that could be wrong. and what sort of cost i'm looking at for two front shocks. They will only buy from parkers so i'm not really sure.
    To top this all off, i lost the car all last week making work hell.
    Driving home from the garage today the service light came on. So car is booked in for service monday
    Any ideas, suggestions or help would be great!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Your profile says your car is 2003 so its not a facelift. If your profile is wrong then you car still may be under warranty 3 years or 60k which ever one comes sooner.
    Nottingham
    whats the difference between face lift and pre face lift. Sorry :-(
    Its an 03 plate. I have had it since september and its done 80,000 miles
    Regular Member old cruiser's Avatar
    slough
    Could be Rad' mounts and revised ones are available from VX.
    Cheers Pete
    Jun 2007
    Black Country
    Quote Originally Posted by nick-v2.2 View Post
    PreFace lift had square looking headlight
    Face lift has long and thin headlights
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    I have the same problem garage cannot find anything so i also wait to see what response you get as to what it could be
    Garage i use have said wait till it gets worse and then it will be more visable as to what part the problem is coming from
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    same here when i go over speed bumps sound like the suspension is scratching and it also sounds like the under belly tray is scratching on the road over speed bumps
    Nottingham
    well i dont know if it helps.
    Garage really reckon its the shocks but are going to look into it monday.
    It appears only to be coming from my passenger side wheel.
    As soon as i get it sorted will let you know :-)
    Birmingham
    confused Noise
    Same here i asumed that it was perhaps the black plastic skirting on the front as the noise mine makes as you go over a speed bump is dependant on how hard i go over them. Have been known to get a clunking noise from front passenger side aswell but only happened a couple of times and then never happened again.
    Nottingham
    ok car went in for service yesterday.
    Turns out spark plugs haven't been replaced in the 5 years of the car been on the road. and the oil was nearly paste.
    They happily showed me. So glad i had the service.
    Car seems to be running a lot quicker. and smoother.
    Garage have said it could be the anti roll bar, but because of it raining they are going to check it on saturday.
    Apparently removing the drop links, or undoing part of it, then driving over the speed bumps can indicate if that is the problem. They are also going to check the radiator bushes.
    I'll let you all know saturday.
    Nick
  1. How to fit Front Passenger Side Door glass
    By thehoq in forum Bodywork & Interior
    Last Post: 14th March 2013, 15:59
  2. Replies: 11
    Last Post: 27th June 2012, 21:54
  3. whine from front passenger side
    By skip85 in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 22:59
  4. PI + B4 fitted - clunking noise from drivers side front
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2010, 20:20
  5. Front Passenger Side Brake fire??!!!!
    By VinnyPeewee in forum Suspension, Wheels & Brakes
    Last Post: 6th December 2007, 15:07
vectra crunching over speed bumps
