Thread: Thermostat location? Sloppy Stick!
    uk
    Default Thermostat location? Sloppy Stick!
    Hi can anyone tell me where the thermostat is on a 2.0 DTi, my gauge either doesnt work or barely moves sometimes, after reading on here it seems the thermostat needs changeing but havent come across any info about my version Vectra, on a different note has anyone changed their gear stick, mines sloppy and I think its the ball-socket end worn, had a look and looks complicated with the cables etc?
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    According to the Haynes bible the thermostat is located on the front right-hand end of the cylinder head, by the air filter box, and is integral with the housing. Looke like a normal two bolt fixing after removing the pipes and the top cover of the engine.
    uk
    Cheers, thanks for the fast response
    Jul 2006
    TENTERDEN KENT
    As to the gear level problem, I think you could well do with a manual as it looks a bit long winded if you have play in that area. Have you looked in the "HOW TO" section???
  1. Thermostat location - 2.2 Direct
    By Big Dave in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 12:59
  2. Z20NET Thermostat Location
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 21:58
  3. sloppy gear stick
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2009, 08:10
  4. 3.2 thermostat location
    By Big Sig in forum Engine & Drivetrain
    Last Post: 28th September 2009, 19:49
  5. Thermostat location 2.0dti
    By bran.c in forum Engine & Drivetrain
    Last Post: 14th October 2007, 11:20
