Results 1 to 10 of 16
Thread: Upgrading rear brake caliper help needed
    Regular Member Baz07's Avatar
    Lancashire
    Default Upgrading rear brake caliper help needed
    I have the full rear 292mm brake setup (disks calipers and carriers) sitting in my house ready to fit.
    Now i have a problem in that the handbrake cable goes through a bracket on the caliper with a black plug/grommet that won't budge.
    Anyone that has done this upgrade or has had to replace the handbrake cable at any time, could you give me any advise as to how to remove this.
    Many thanks in advance.
    Maida Vale
    Just out of interest, what size do you have on the front?
    Lancashire
    Quote Originally Posted by Thomas1 View Post
    314mm
    Ashington, Northumberland
    There should be a slot in the cup that the cable outer sits in. Soak the cup and cable in penetrating fluid for a while and then using an old screwdriver as a punch, place the blade edge of the screwdriver in the slot and give the end of the outer cable a little tap in the direction it is to come out and this should dislodge it. Works every time for me
    Lancashire
    Gary i have looked at the calipers i have ready to fit that have been removed and the handbreak cable has been cut but the black cups are still stuck inplace, but i can see no slot in them
    Picture of the piece i am talking about
    Cant see any pic mate
    Lancashire
    Quote Originally Posted by GARY3306 View Post
    I can see...
    Here it is again
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Are you going to re-use the gromit if not then drill it out if you are they can't be pricey from Vx and are they on your current handbrake cable? if not drill em
    Full Member lizard's Avatar
    Oct 2006
    southampton
    16 Post(s)
    have you tried heating it up
    Lancashire
    I can remove these ones by wripping them out as they are on the calipers ready to fit, my problem is how to remove the same things including the cable on the ones fitted to the car at the moment without damaging them because they have to be refitted.
  1. Brake Caliper Rewinf Tool Needed - Leeds
    By arkhan78 in forum Yorkshire (RO - vacant)
    Last Post: 3rd December 2011, 16:16
  2. Rear brake Caliper
    By scoles1 in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 23:16
  3. Rear brake caliper
    By NI-2.2SRI in forum Handling & Braking
    Last Post: 16th March 2009, 19:33
