Results 1 to 10 of 29
Thread: Those that have changed No.3 injector loom
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Those that have changed No.3 injector loom
    .....just a question really..
    Did you do just no.3 or all 4... When you buy the part from Vx the part has multiple wires, but you are supposed to select the right wire thickness for your car... So to do all 4 I would need 4 x the part...
    Regular Member CDTi Mike's Avatar
    Dec 2005
    Melksham, Wiltshire
    When Vx did mine under warranty they only changed the wire and plug on injector no 3.
    All I can see is a slightly different style plug with retaining clips in a different place, and no juddering problems since.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Same here mate - did my no.3 only, and also got the latest ECU upgrade as thats supposed to be done also aparently - not that i see that that makes a difference..
    runs sooo much better now - pulls much better, just wondered if I should do the other 3 as a matter of precatuion.
    Dec 2005
    Melksham, Wiltshire
    Oh yeah, forgot that bit, they did do the ECU upgrade on mine too.
    I'm not too worried about the other 3 as the dealership said they haven't done any of the others and they've not seen any issues.
    Must admin i'm on 72k now and like I said above, there's not been any issues with the injectors since.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I had all 4 done to be on the safe side. You will need 4 packs of wires if you did this.
    wigan
    is there a thread anywhere with a step by step guide (pics as well would be great) of how to do this fix?
    Regular Member Avenged's Avatar
    Liverpool
    is it worth me gettint the dealers to check mine tomorrow, as they are fitting a new transmitter for the radio!??
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Quote Originally Posted by merikiito View Post
    I did injector plug 3 on NOV 25th and the car felt like new after. Went down to Vx's 2 buy the kit for the other 3 injectors just to be on the safe side! It should cost less than £50 to do all injectors urself!
    Jan 2008
    South Wales
    Quote Originally Posted by phildjohnson View Post
    Ill do a HOW2 tomorrow m8 as im doing my other 3 injectors!
    wigan
    much appriciated
  1. Injector washers changed
    By collyb in forum Engine & Drivetrain
    Last Post: 26th April 2011, 21:16
  2. New injector loom. 1.9 150
    By Mopar Man in forum Diesel Engine related
    Last Post: 6th April 2011, 20:04
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. CDTI 150 Injector Loom
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2009, 17:06
  5. No 3 injector plug changed but still misfires
    By bygumlad in forum Engine & Drivetrain
    Last Post: 27th August 2009, 21:03
