Thread: Lambda
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default Lambda
    Car just failed mot on emission readings. EML light is on and code reading p0170, how likely is it to be the lambda at fault and are they common to go vectra c.
    Sorry by the way 1800 engine
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    p0170 is fuel trim bank one,
    Could be O2 sensor.
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Sorry if I sound a bit of an arse, but isn't O2 short for oxygen which would then mean that is the Lambda as this is A.K.A as oxygen sensor.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by VECTRAMAN View Post
    yes it is m8
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, it is an O2 sensor, lambda is the air / fuel ratio term.... Just to be geeky.
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Cheers guys ,changed today came off really easy.Re test thursday so fingers crossed,
    Nicking Ya Dinner.
    If that don't sort it, you need 1 new air filter and 1 bottle of injector cleaner in half a tank of juice, give it a 20 mile run when hot with illegal speed spurts where safe to do so, and on the day have the car as hot as possible when you take it in for testing and ask for the gas test to be done 1st, hth.
    I've a feeling they've mugged you here, probably tested it with a half warm engine.
    birmingham
    Engine : 3200
    your lucky m8 these can sometime be a right pain in the 455
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Did you use a sensor socket? Or just use a spanner?
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Used a Sensor socket only cost £8 from local motor factors. No room for a spanner in there rad toooo close and manifold shield stops u turning it. Advise spray WD40 on cold manifold day before then remove when hot , came out litle effort.
  1. Intermittent Lambda ?
    By JagRigger in forum Engine & Drivetrain
    Last Post: 6th January 2013, 08:11
  2. Lambda sensors...
    By nikroc in forum Engine & Drivetrain
    Last Post: 29th November 2012, 21:56
  3. EML 2.0T Lambda or CAT
    By a1ant in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 20:53
  4. Cat Or Lambda
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:03
  5. Lambda help
    By Barnes in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:42
vauxhall vectra c lambda socket www.vectra-c.com
