Results 1 to 10 of 11
Thread: Adapter Lead
    Regular Member Damian's Avatar
    Market Drayton
    Default Adapter Lead
    This adapter lead has 2 connections for reverse gear and speed signal. It's the adapter lead for CD30 owners and Pioneer head units. (Hot topic at the moment)
    Where would I pick these feeds up from
    Regular Member pauls898's Avatar
    Malvern
    The speed signal can be found on the iso block, its the SDVC labled wire for the speed Dependant Volume Control of the standard VX headunit.
    The reverse I just ran a wire from the reversing light blub in the rear light cluster and that works fine.
    Market Drayton
    Excellent thankyou. Out of interest what is acheived connecting up to reverse
    Malvern
    I can only assume your installing a Sat Nav, if so the reverse is to tell the unit that you have not turned around and are really going backwards. If on the other hand your fitting just a video / DVD player, these can be set-up with a reversing camera, and again to tell the unit you want the reversing camera activated.
    Some units like mine also has a connection to the hand brake so you can't watch your DVD's untill you apply the hand brake, Crafty lol.
    Regular Member Rikkiola's Avatar
    Feb 2006
    Dunstable
    is that the 152 wotsit thingy to maintain steering controls?
    Let me know how you go with that
    Just fitted the standard VX wiring loom after replacing my CD30 with Pioneer DEH P70BT (as you may have read)
    If you find a solution to keep the unit on without the ignition on...let me know !!
    Market Drayton
    Quote Originally Posted by pauls898
    I'm not but this is a standard Pioneer lead so must cover all head units including those with built in Sat Nav and DVD. So if I get one I won't need those connections as I only have the MP3 player / bluetooth unit
    Market Drayton
    Quote Originally Posted by Rikkiola
    It is the 152 lead, I am still yet to find a UK stockist. Only a dutch one so far.
    I have the same headunit
    I have been told the only way to keep the power on is to wire the ignition and live feeds to a permanent live on the car. Means you would have to switch the unit off everytime you got out the car
    Malvern
    I wired mine up to the cars switch ingition so that with the key in ACC posistion the radio would come on and stay on till you removed the key, like the orginal one did and it would work from the VX timer so it would power off after an hour of being left on.
    The trick here is to use a power relay, because the cars switched ingintion can only supply a very small current, ie a few mA. So I wired up a transistor to switch on a relay which then supplys the main current direct from the battery. However when the key is removed this relay drops out turning off your radio/headunit. Smart hey....
    If you then also wire up the switched output back into your car this in turn keeps the timer alive alowing it to stay on with out the ingintion being on, and this also powers the roof aerial amp, but I have to say even with that working the reception on FM is **** to say the least, so I have just orderred the DAB hideaway unit to further expand my system.
    Market Drayton
    Hi, this is exactly what I am after. Was this easy to do, given that my electrical experience with my car is somewhat dubious. If so is there any chance you could knock up a quick how to and a parts list
    Malvern
    Will do, but I'll have to figure out how I can draw a schematic on here, probably draw one up and post as a pic, rather than trying to explain how to do it. I'll see what I can do.
  1. Do i need an adapter lead or not?
    By wesleyneary in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2011, 19:35
  2. USB Adapter
    By chinarose87 in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2010, 01:36
  3. Kenwood head unit adapter to Connects2 CANBUS stalk adapter
    By paulw77 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2009, 07:01
  4. cd 30 adapter
    By chrispatch88 in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2008, 21:38
  5. VDA Adapter
    By caravaner-tony in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 18:48
