Results 1 to 10 of 11
Thread: Signum 1.9cdti Sluggish at Low Revs
    North West
    Question Signum 1.9cdti Sluggish at Low Revs
    HI All,
    Hope someone can help me with this one?
    Had my Signum since July and recently started to experience a lack of acceleration at low revs.
    Particularly noticeable when setting off is really slow till it hits about 2000 rpm then kicks in fine. From then on , through the revs /gears no problem.
    The car is 3 years old in March (52K miles)so want to get it sorted before the warranty expires. Any ides before the garage tell me, 'Oh they all do that,sir'!
    Steve
    Regular Member cameraman's Avatar
    Leicester
    Looks like another EGR valve this was yesterdays! http://www.vectra-c.com/forum/showthread.php?t=66287
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    when was it last serviced ???
    Midlands Mod Shop - NFFC.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by cameraman View Post
    i would put money on it being the egr m8
    Bristol
    Default Gutless Vectra
    I hired a vectra 1.9 150bhp vectra with only 200 miles on it . Pulling away Into traffic was dangerous just would not go below 2000rpm.
    Regular Member pugs,signum's Avatar
    swansea
    Quote Originally Posted by spj555 View Post
    HI All,
    Steve
    take a look at this thread and see if your car is suffering with swirl valve problem! as my car started with a lack of power under 2000rpm turned out its the swirl valves but guttinly for me i have no warranty and the 1.9cdti (150) engines are prone to swirl valve failure will be doing the job myself to save hundreds of £ss as it dont come cheap!
    http://www.vectra-c.com/forum/showth...ght=glow+plugs
    Glasgow
    Swirl valve, EGR or turbo!
    Belfast
    I'm betting swirl valves jammed open.
    swansea
    I took mine to a garage and they put it on laptop to check egr and that was fine (was hoping it was EGR as that would be the cheapest to replace lol) also check out the airflow meter as thats meant to give some touble with power heres a thread how to check it.
    http://www.vectra-c.com/forum/showth...=airflow+meter
    Regular Member Drew's Avatar
    Sedgefield
    Vehicle : 2017 Insignia ST
    Trim : Sri nav vx line
    Engine : 2.0 TD 170 auto
    Year : 2017
    Just had the inlet manifold changed on mine for the new one and the car is like new again. Except the EGR is showing faulty now and wasn't before the change (I will be checking it's connections tomorrow). Check the swirl flaps yourself there is a thread on here or get the dealer to do it. Mine were that worn at 81,000 that they were lifting on their axis and letting all the boost out so it would not pull below 2500rpm. As a consequence the Diesel particle filter was sick and showing a fault and that was putting the car into limp mode, it's now fine.
  1. sluggish revs and white smoke
    By n8sby in forum Engine & Drivetrain
    Last Post: 2nd July 2012, 16:19
  2. Sluggish Performance with Signum 1.9 CDTI
    By flensberg in forum Engine & Drivetrain
    Last Post: 1st May 2010, 08:59
  3. 2.0T sluggish 1500K-2K revs ?
    By moorlander in forum Engine & Drivetrain
    Last Post: 17th August 2009, 01:18
  4. no wonder the 1.9cdti 150ps are a bit flat at low revs
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2009, 12:18
  5. '03 2.2 DTI Signum - Revs drop... struggles to idle... then dies... :-(
    By garthmatthews in forum Vectra C / Signum Troubleshooting
    Last Post: 12th December 2008, 12:47
sinum diesel sluggish
no boost on low rews 1.9cdti
Signum slugish at low revs
vauxhall 2.0 cdti sluggish
vauxhall signum diesel sluggish
vectra c 1.9cdti sluggush
vectra 1.9 cdti no power at low revs
vauxhall 1.9cdti slow
vectra c 1.9 down on power
