Results 1 to 10 of 27
Thread: Tyre - Chunk Missing - Is it dangerous?
    Birmingham
    Default Tyre - Chunk Missing - Is it dangerous?
    Hi Guy's,
    My wheels on my Vec-B were pointing outwards this morning and I somehow managed to spot this chunk missing out of my tyre.
    Its on the outer part of the tread.....cant seem to work out how on earth this happened.
    You opinions please folks!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    I had a very low car in the past with tyres with worse than that i wouldnt worry too much, obviously it would be better for you to change it as in effect thats close to the ''wire''
    May 2008
    Doncaster
    Don't mean to get all serious on this one but here I go!
    As your tyres are the ONLY thing holding your car on the road and your life depends on them then don't risk it. Yes it will cost you but if you had an accident and died then what's worse!
    That tyre looks like it's got a lot of tread left which sucks but it's still not worth risking it and get a couple more.
    If you do have an accident and the investigator sees that then they could use it as an excuse not to pay you out. Not to mention if that chunk goes below 1.4mm of tread then you could get a fine from the police! (I think).
    Don't risk it - CHANGE IT!
    EDIT: Plus if that chunk is low enough you could have a blow out as your tyre expands in the heat and at 70mph (assuming you stick to the limit ) then that's not good!
    Regular Member mark_w's Avatar
    cheshire
    i'd say just drive it. the chunk isn't lower than the base of groove, so even if lightning did strike twice, it would be no closer to the braiding than the base of the treads, which must have plenty in reserve.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As there is plenty of tread, the missing bit doesn't put it below the tread depth anyway, so I personally wouldn't worry about it too much. I reckon it would pass the MOT inspection and the police probably wouldn't notice or do you even if they did.
    Regular Member gromit's Avatar
    Cumbernauld
    I wouldn't replace it as it hasn't cut deep enough.
    May 2008
    Tyneside
    The cut in the base of the tread looks more serious than the chunk of missing tread. Have you checked there is no air leaking out (soapy water test). In the past I have removed nails from tyres and if they are not leaking I've just carried on driving on them. A cut is worse, in this case I would probably just carry on driving but check it perdiodically.
    spoons
    Guest
    Did it taste nice
    I haven't tried Continentals yet... prefer Eagle F1's myself
    Birmingham
    Quote Originally Posted by tridley View Post
    Havent tried the test mate, I think i later today, but there dont seem to be any air loss as its been driving fine-no pulling etc, and the tyre looks quite well inflated, as it was when I had the change over done!
    Quote Originally Posted by spoons View Post
    Did it taste nice
    Someone has let him out!!! !
    Bye bye Vec B
    - Hello Siggy!
    Jun 2007
    Black Country
    Nothing to worry about with that, if everyone on here looked at there tyres i think they might be shocked
  1. A nail took a chunk out my alloy
    By MCCABE in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 18:45
  2. Dangerous!
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 23:33
  3. Mad, bad and dangerous to know!
    By Mrs D in forum The 'Off Topic' room
    Last Post: 7th August 2008, 08:04
  4. Dangerous or Fun? .. ..
    By AJA in forum General Chat
    Last Post: 22nd June 2007, 14:29
air coming out from tire chunk missing
lowered car chunk out of tyre
