Thread: 3.0 V6 Power loss after a wash???
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Unhappy 3.0 V6 Power loss after a wash???
    as titled i washed my very dirty siggy 3.0 V6 CDTI and driving it this morning seamed normal till i put the boot down then there was hesitation and then it went put the boot down again and more hesitation??
    No warning lights on just checked the air filter and turbo hoses and no problems there??
    i know there is another thread on here with a similar problem but alot of those 3.0 are the newer engine and was wondering if anybody with the older pre 05 engine experiance anything similar??
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    I'll hazard a guess that you used a pressure or jet washer?
    You've already looked at what I was going to suggest - wet air filter but other than that, I can't think of anything else.
    Hopefully somebody more informed will be along
    EDIT - just a thought, how about disconnecting the battery for an hour and re-setting the ECU?
    Oct 2007
    Back in Belfast!!!!
    After i have drove it again after the air filter strip out it has not done it again but if it happens again i will try the ECU reset Cheers gtr1000
    Regular Member poves's Avatar
    lancashire
    The multiplug on the airbox may be damp , wd40 mate .
    Oct 2007
    Back in Belfast!!!!
    i took the siggy to see a non vx mech friend of mine today to see what he thought the hesitation might have been altho the car was perfect today no problems still no lights???
    he seams to think it might be the air flow meter any mechs or experianced peeps on here think that too??
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by BIG NEIL View Post
    We all seem to be on the right lines here. If (and I don't know), you pressure washed and aimed the jet at the grille and air intake area at the front, water can pool up in the intake pipework (well it can on my 3.2V6). You'll then be sucking in very moist and very damp air through the air filter, maybe even sucking water droplets in. If these collect on the air flow sensor (MAF?), you'll get incorrect air/fuel readings. The MAF can be removed and cleaned but as all now seems well (the MAF has dried out), I'd leave well alone unless the problem comes back.
    lancashire
    Yes that's what I meant , the multiplug on the maf was damp , limphome mode lack of power - wd40 solved it lol .
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. 2.2 dti power loss
    By dylan1875 in forum Engine & Drivetrain
    Last Post: 4th February 2011, 23:35
  3. Loss of power
    By Danny 75 in forum Engine & Drivetrain
    Last Post: 20th January 2011, 19:08
  4. loss of power!!!!!!!!
    By axelf in forum Engine & Drivetrain
    Last Post: 5th May 2010, 14:05
  5. Loss of power
    By rob123 in forum Engine & Drivetrain
    Last Post: 13th May 2008, 18:22
