Thread: HELP! front suspension problem
    Regular Member pinoy's Avatar
    newport,gwent
    Default HELP! front suspension problem
    front suspension in the passenger side is gone.went to the garage adviced me to change both sides.they want to charge me £210 for both inc labor or £105 inc. labor for just the one suspension.is it the price reasonable and is it really advisable to change both sides into new ones?.i need some advise ASAP PLEASE.
    What did they say the problem was?..Front suspension is a bit vague..
    SOUTH SHIELDS
    If you mean the shockers yes change both sides at the same time
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    If its the shock absorbers you may well get aftermarket one's cheaper and get a local garage to fit them.
    As your car is 2003 springs would be changed under warranty..Dampers would be a fight to get under warranty unless you had NetworkQ cover..
    Not a lot else would need replacing in axle pairs thou..
    What work have they advised you have??
    newport,gwent
    its actually the shock absorbers.but actually guys i made the decisions today to have it done.i need my car for work.its only the one side for £95 inc. labor,tax.(only a generic shock)i didn't see your suggestions before i went to the garage.do you think guys i made the right decision.thanks all!!!
    newport,gwent
    its actually the shock absorbers.but actually guys i made the decisions today to have it done.i need my car for work.its only the one side for £95 inc. labor,tax.(only a generic shock)i havent seen your suggestions before i went to the garage.do you think guys i made the right decision.thanks all!!!
    Pinoy..
    dampers must be replaced in axle pairs to maintain an even balance to the car when driving and especially under braking where having a mis-matched pair of shocks could prove deadly..It hurts to have the pair replaced if only one has gone but what price for safety??
    At least at the main Stealers you should have a greater degree of comeback if there are any further problems...
    What mileage did they go at?? Just for interest..
    newport,gwent
    thanks for your avised guys!
  1. Front suspension problem
    By chrisvectra in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2012, 00:17
  2. Suspension problem
    By Fishmichael in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2011, 21:29
  3. Suspension problem?
    By tony-1977 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2010, 18:15
  4. rear suspension problem
    By philjensam in forum Suspension, Wheels & Brakes
    Last Post: 12th April 2010, 01:18
  5. possible suspension problem?
    By Big Knox in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 22:22
