Thread: Passenger side air vent removal
    Wolverhampton
    Default Passenger side air vent removal
    Hi there, can anyone out there give any tips on how to remove my passenger side air vent, its an 08 sri (if that makes any diff) cheers, Mark.
    playing with spanners
    on my pre-face lift all i have to do is pull the trim of under the vent and there is 2 torxs to undo under the vent , dont know if the face lift is any diffrent
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by bigron1988 View Post
    thats the way i changed mine as well due to the vent slats collapsing
    Regular Member Robbie69's Avatar
    pretty sure it's the same mate!
    Regular Member G.T.S's Avatar
    Helsinki
    do you mean the vent wich is in the midle console or in the side??
    Wolverhampton
    Nice one guys, thanks. Is it a common problem then, the slats collapsing?
    birmingham
    Engine : 3200
    Quote Originally Posted by 726181 View Post
    both my 2 side ones were broke, 2 mins job m8
    there was a thread on this if you do a serch
    2 of mine have
    Apr 2009
    Northants
    Hi all,
    The bottom slat in my centre air vents has flopped flat!
    The vent seemed to get stuck, and when I used a little more force on the vertical control, the bottom slat seems to have become detached.
    From the limited view I have of the inside of the vent, I think that this could quite easily be repaired if I can remove the centre vent and screen surround from my Vectra but unfortunately I haven't a clue how to do this.
    I've seen references to a thread on this subject that may have some instructions, but I've not managed to find it yet
    Any help would be appreciated!
    Many thanks,
    Dave
    Essex
    28 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    same as per instructions for side vent
  1. can i get access to passenger side air vent
    By dodus in forum Bodywork & Interior
    Last Post: 18th April 2012, 14:19
  2. Air vent removal
    By Jabbekot in forum Bodywork & Interior
    Last Post: 10th November 2010, 11:11
air vent removal vectra c
how do you remove an air vent in a vectra c
