Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: Vectra 3.0 CDTI engine code problem
    Bristol
    Default Vectra 3.0 CDTI engine code problem
    Can anyone help . I have a 3.0 CDTI Vectra 04.
    Put you foot on throttle restricted resonce, let foot up put down again and away it goes no problem.
    When it cruises at about 1500rpm it gets a hesitation but if you accelerate it stops.
    When cold car ticks over ok on tickover when warm EML comes on code PO105 Pressure Boost Sensor.
    Have replaced EGR, Flywheel , And Pressure Boost Sensor.
    Bristol
    If I go from start. it will not go passed 2000rpm. if you blip throttle it picks up and accelerates normal .
    if you pull away quick going uo through the gears it accelerates fine. That because you a bliping the throttle when you change gear. But as soo as you let your foot off and cruise it starts to histate like mad . put food down nothing happens ,blip throttle and accelerate its fine again.
    Is the turbo 100%? if the sensor isn't seeing the right boost levels it may flag up a sensor issue but it could be not seeing what it should due to the turbo not performing.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Any splits in the boost pipes
    Bristol
    I have checked pipes . I have replaced every Sensor on the car. I am trying to get my hands on a secondhand turbo at the moment from a saab or vectra as they are both the same.
    Regular Member 30ltr nutter's Avatar
    dunstable
    hi this is what i found it could be electrical and not pressure related
    P0100 Mass Air Flow Sensor Circuit Low Input C-07
    P0100 Mass Air Flow Sensor Circuit Range/Performance C-07
    P0105 Boost Pressure Sensor Circuit High Input C-08
    P0105 Boost Pressure Sensor Circuit Low Input C-08
    P0105 Boost Pressure Sensor Voltage Supply Circuit High Input C-08
    P0105 Boost Pressure Sensor Voltage Supply Circuit Low Input C-08
    P0115 Engine-Coolant Temperature Sensor Circuit High Input C-09
    P0115 Engine-Coolant Temperature Sensor Circuit Low Input C-09
    P0115 Engine-Coolant Temperature Sensor Circuit Range/Performance C-09
    P0190 Mechanical Fault in Fuel System (Partial Load) C-14
    P0190 Mechanical Fault in Fuel System (Full Load) C-14
    P0195 Engine Oil Temperature Sensor Circuit High Input C-10
    P0195 Engine Oil Temperature Sensor Circuit Low Input C-10
    P0400 Exhaust Gas Recirculation Circuit High Input C-16
    P0400 Exhaust Gas Recirculation Circuit Open C-16
    P0400 Exhaust Gas Recirculation Flow Excessive Detected C-16
    P0400 Exhaust Gas Recirculation Flow Insufficient Detected C-16
    P0500 Vehicle Speed Sensor Circuit High Input C-22
    P0500 Vehicle Speed Sensor Circuit Incorrect Signal C-22
    P0500 Vehicle Speed Sensor Circuit Range/Performance C-22
    P0560 System Voltage Low Input C-03
    P0606 Replace Control Unit C-02
    P0703 Brake-Light Switch Circuit Incorrect Signal C-11
    P0703 Brake-Light Switch Circuit Incorrect Signal (Ignition On) C-11
    P0704 Clutch Switch Input Circuit Malfunction C-12
    P0725 Engine-Speed Sensor Input Circuit Incorrect Signal C-18
    P0725 Engine-Speed Sensor Input Circuit no Signal C-18
    P0725 Engine-Speed Sensor Input Circuit Signal Range/Performance(Overspeed) C-18
    P1110 Variable Intake Air/Variable Swirl (Diesel) High Input C-17
    P1110 Variable Intake Air/Variable Swirl (Diesel) Circuit Open C-17
    P1125 Boost Pressure Solenoid Valve High Input C-15
    P1125 Boost Pressure Solenoid Valve Circuit Open C-15
    P1125 Boost Pressure Solenoid Valve Excessive Flow Detected C-15
    P1125 Boost Pressure Solenoid Valve Insufficient Flow Detected C-15
    P1180 Fuel Temperature Sensor Circuit High Input C-14
    P1180 Fuel Temperature Sensor Circuit Range/Performance C-14
    P1220 Injection Timing Control Excessive/Insufficient Flow Detected C-14
    P1335 Injection Pump: no Engine Speed Input Signal from Control Unit C-18
    P1345 Injection Pump: Camshaft Speed Malfunction C-14
    P1501 Immobiliser Not or Wrong Initialised C-05
    P1502 Immobiliser No Signal C-05
    P1503 Immobiliser Wrong Signal C-05
    P1515 Pedal Position Sensor Circuit High Input C-06
    P1515 Pedal Position Sensor Voltage Supply Circuit High Input C-06
    P1515 Pedal Position Sensor Voltage Supply Circuit Low Input C-06
    P1515 Pedal Position Sensor Potentiometer Error C-06
    P1515 Pedal Position Sensor Brake Switch Error C-06
    P1515 Pedal Position Sensor General Error C-06
    P1530 A/C Compressor Cutoff Relay Primary Circuit High Input C-21
    P1530 A/C Compressor Cutoff Relay Primary Circuit Open C-21
    P1560 System Voltage High Input C-04
    P1560 Injection Pump: System Voltage Range/Performance C-04
    P1604 Replace Control Unit C-02
    P1604 Variant Coding Wrong Code Programmed C-02
    P1604 Variant Coding Not Programmed C-02
    P1620 Replace Control Unit C-02
    P1625 Power Supply Relay Switched Off too Late C-04
    P1630 Fuel-Injection Quantity Circuit High Input C-14
    P1630 Fuel-Injection Quantity Malfunction C-14
    P1631 Replace Control Unit Injection Pump C-14
    P1635 Glow Device Circuit High Input C-19
    P1635 Glow Device Circuit Open C-19
    P1635 Glow Device Circuit General Error C-19
    P1650 CAN: Device Offline C-14
    P1650 CAN: Device Hangup C-14
    P1651 CAN Receives Error C-14
    P1651 CAN Transmits Error C-14
    P1651 Injection Pump: CAN Malfunction C-14
    P1660 Fuel Cutoff Solenoid Valve Circuit High Input C-14
    P1660 Fuel Cutoff Solenoid Circuit Open C-14
    P1660 Fuel Cutoff Solenoid Valve Malfunction C-14
    P1690 Malfunction Indication Lamp (MIL) Circuit High Input C-24
    P1690 Malfunction Indication Lamp (MIL) Circuit Open C-24
    P1694 Glow Time Telltale Circuit High Input C-25
    P1694 Glow Time Telltale Circuit Open C-25
    Bristol
    Default Thanks for the codes.
    I have all the codes on the VX tis. My snap on scanner flages up p0105 pressure boost sensor range and performance.
    I have changed this sensor but still the same.
    dunstable
    that code could mean many things u will have to start at the basics check the intercooler and pipe work ect check that u have vacumn at the boost control on top of the turbo. i had the same code when the intercooler pipe came off and it will do the same if a pipe has got a small hole in it. because it says sensor it does not allways mean its the sensor it just means the fault lies in that part of the system
    Bristol
    Hi thanks for that. I will check the pipes again before replacing turbo.
    Bristol
    Quote Originally Posted by 30ltr nutter View Post
    Another thing I did not mention is that the hesitation is there when stopped just reving the engineto about 1600rpm.
  1. 1.9 CDTi - Have you had a problem with this engine or not?
    By Ian in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2013, 14:18
  2. engine code for vectra vxr
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 19:20
  3. P0700 Engine ECU Code Vectra 1.8 Auto 2001
    By Laura in forum Vectra C / Signum Troubleshooting
    Last Post: 29th May 2009, 19:40
  4. Cdti 150 Engine Problem
    By scad2k in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2008, 21:31
  5. V6 CDTi faulty engine problem update
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2007, 21:20
vectra c 3.0 cdti p0105
3.0cdti p0105
p0105 vectra c 3.0 cdti
P1501 Immobiliser Not or Wrong Initialised C-05 how to fix
opel 3.0 cdti engine number
p0700 signum z30dt
vectra c 3.0 v6 cdti engine number
error p0105 vectra c 3.0 cdti
vauxhall vectre 3.0 cdti
3.0 cdti nothing happens full throttle
vectra 3.0 cdti problems
3.0cdti p0105 boost sensor
p1630 fuel injection quantity circuit out of range
