Thread: 3.0 CDTI Hesitation and EML
    Bristol
    Default 3.0 CDTI Hesitation and EML
    Can anyone help . I have a 3.0 CDTI Vectra 04.
    Put you foot on throttle restricted resonce, let foot up put down again and away it goes no problem.
    When it cruises at about 1500rpm it gets a hesitation but if you accelerate it stops.
    When cold car ticks over ok on tickover when warm EML comes on code PO105 Pressure Boost Sensor.
    Have replaced EGR, Flywheel , And Pressure Boost Sensor.
    EVERYWHERE
    Quote Originally Posted by sb1uk View Post
    Try putting this in 'Engine and drivetrain' forum where you are likely to get more response.
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    what happens if you go from coasting to flat out, does it generate a fault code, and just not pickup at all? but if you go from a rolling start and gentle accelarate it picks up ok?
    Bristol
    If I go from start. it will not go passed 2000rpm. if you blip throttle it picks up and accelerates normal .
    if you pull away quick going uo through the gears it accelerates fine. That because you a bliping the throttle when you change gear. But as soo as you let your foot off and cruise it starts to histate like mad . put food down nothing happens ,blip throttle and accelerate its fine again.
    Regular Member ssmotoboyz's Avatar
    wednesbury
    mine had same symptoms all it was was a very dirty fuel filter
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Could be a torn turbo vacuum hose (control line) not letting the turbo spin up, or a torn turbo pressure hose letting boost pressure leak out.
  1. CDTI Hesitation issues....?
    By johns159 in forum Insignia car chat
    Last Post: 24th August 2011, 23:17
  2. 1.9 Cdti 120 hesitation
    By sb1uk in forum Engine & Drivetrain
    Last Post: 13th July 2011, 13:08
  3. 1.9 CDTI 120 Hesitation Judder.
    By CDTI120SXI in forum Engine & Drivetrain
    Last Post: 8th July 2011, 17:45
  4. 1.9 cdti Hesitation at 2500 rpm
    By alkez100 in forum Engine & Drivetrain
    Last Post: 3rd May 2010, 21:18
  5. Cdti Hesitation At 2000 Rpm
    By CRAIG in forum Engine & Drivetrain
    Last Post: 9th October 2006, 13:29
