Thread: Road spray noise from rear
    Lancashire
    Unhappy Road spray noise from rear
    Hi all,
    I'm not sure whether my ears are being over sensitive, but I definately didn't notice the same noise on my previous 04 SRi.
    I can hear alot of road spray noise coming from the rear wheel arches. To the extent that it sounds like a constant "ssshhhh" and radio has to be turned up.
    It doesn't help that the current cold weather has resulted in the roads being gritted. All I can hear from the rear is the noise of salt hitting the wheel arches.
    Does anyone else have this "feature"? Is it case that the Elite has a higher suspension that the SRi so you can hear it more?
    Steve
    Regular Member mark_w's Avatar
    cheshire
    there was a thread about rear end noise the other day.
    http://www.vectra-c.com/forum/showthread.php?t=54068
    Lancashire
    Cheers mark..but it's not a wheel mechanical issue. It's definately water spray noise as it only happens in the wet
    It's just quite a bit louder than I would expect.
    cheshire
    have you checked your rear windows are firmly shut? and that the rear door seals don't have any splits or damage?
    Regular Member pscocoa's Avatar
    Oct 2007
    Sandhurst Berkshire
    I noticed this noise for the first time today on long journey back down motorways - did a search for road noise and came up with this link and one on tyre types as possible cause of problem. Seems unlikely to be other fault which is a relief - roads had been gritted
  1. Road Noise
    By Andyjarvis in forum Suspension, Wheels & Brakes
    Last Post: 4th April 2012, 16:53
  2. road noise
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2011, 11:12
  3. Excessive Road Noise / Rear wheel camber
    By ph67 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 19:19
  4. Road Noise / Rumbling rear wheels solved?
    By Raze in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2008, 17:30
  5. Road Noise
    By Raze in forum Vectra C / Signum Troubleshooting
    Last Post: 27th October 2007, 12:57
