Results 1 to 3 of 3
Thread: Key Fob Problems
    Wiltshire
    Default Key Fob Problems
    I've got an 04 Vectra where both key fobs won't work to unlock the car remotely, so am having to lock/unlock it using the key. Only problem is the alarm goes off whenever i open the door, but stops as soon as i put the key in the ignition, so luckily am still able to start the engine. Replaced the battery in the main fob but this hasn't fixed the problem. It was working intermittently but has now completely given up. Any ideas would be greatly appreciated. Thanks. PS - the button for the boot works fine!
    13 Post(s)
    Have you tried re-sync'ing the fobs, as per the info in the handbook?
    http://www.vectra-c.com/forum/showthread.php?p=627030
    If that doesn't work, then don't lock the car with the key. Instead as a temporrary measure until you've got it fixed - reach in through the passenger door and press the lock button on the drivers door, this should lock all the doors. Then close the passenger door. A word of warning though, the deadlocks won't be set.
    Wiltshire
    Tried re-syncing the key but didn't work unfortunately. Also tried it with the spare key but it's still doing the same thing - boot button works fine, the door lock and unlock buttons don't. Looks like a costly trip to Mr Dealership...! Thanks for your suggestions.
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
vectra c key fob intermittent
vectra c key fob sync
