Thread: pulling to the left
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default pulling to the left
    hi my veccy is starting to pull to the left a bit while accelerating or hitting bumps in the road, also the steering wheel feels a bit shakey ...anyone give me an idea(i have checked tyre pressure)......thanks
    Regular Member Signumv6man's Avatar
    Suffolk
    Trim : Elite Auto
    Engine : 2.8 V6 Turbo
    Quote Originally Posted by Morephun View Post
    If tyres are a bit worn they can go out of balance as they wear, my Vectra B suffered a bit with this and I had to have one set of fronts re-balanced twice during their service life (around 23k miles). Take to someone who will do it carefully and balance them dynamically (i.e. put weights inside and outside to balance laterally as well as radially). Make sure you explain the problem and get what you want !!
    If no difference I suggest putting rears on front to see if that makes a difference - then post again !
    Hope this helps a bit. After that you're probably into worn steering rack or driveshafts.
    Steve C
    wigan
    have you check your tyre pressures
    Ashington, Northumberland
    Quote Originally Posted by phildjohnson View Post
    lol
  1. Pulling to the left.
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2012, 00:23
  2. Pulling to the right, then left.. Help!
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 18:06
  3. Pulling to the left
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 21:52
  4. Pulling to Left
    By Diet1985 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2009, 20:39
  5. Car pulling to left
    By andy1103 in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2009, 22:52
