Thread: front wipers problem
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Default front wipers problem
    i have noticed that the wipers sit about 6 inch up on the screen to where they should be.
    also when i put them on they go down to the bottom of the screen then up and then sit back in the wrong place again....help as its doing my head in
    i have disconected the battery for 30 mins but still the same
    cheers guys
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Guess the arms are set in the wrong place to start with?
    Have they been removed?
    birmingham
    Engine : 3200
    Quote Originally Posted by 900ss View Post
    they were normal to start with and i have not removed them....can the wipers be reset or somthing?
    cheers
    Regular Member GoldenWonder's Avatar
    Durham
    Might be worth checking the linkage anyway. When I replaced my front motor recently I noticed the splined sort of end that links the motor to the actually wiper arm linkage looked quite worn - its quite possible that this might have 'slipped' and put your linkage out of alignment with the motor.
    Should be able to check with the black plastic covers just lifted up.
    birmingham
    Engine : 3200
    Quote Originally Posted by GoldenWonder View Post
    i will have a look in the morning and see, if the linkage is ****ed how much is a new one?
    wish me luck
    Durham
    Well the linkages seem to be around £30 from a scrappy and £70 new.
    On mine, I simply put a new nut on (nylok type) and thats held it OK (fingers crossed) for a couple of months now, so you might only need to do that.
    May 2008
    Bucks
    Sorry i assumed the arms had been removed b4 you got the car?
    Welll if its not the linkage i guess it can only be the park in the motor at fault?
  1. front wipers gone mad
    By tomcat1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2011, 21:33
  2. Problem with wipers
    By Jonathan Barclay in forum Troubleshooting
    Last Post: 24th July 2010, 23:49
  3. Wipers problem vectra 150 sri
    By NAYLAD in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2009, 12:02
  4. Problem with wipers
    By vockycdti in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2008, 07:53
  5. front wipers.
    By Marty J CDTI in forum Bodywork & Interior
    Last Post: 1st September 2007, 22:24
