Results 1 to 10 of 13
Thread: Window wipers take ages to work...
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default Window wipers take ages to work...
    Are they effected by the cold as mine dont work for ages... took an hour today before they would work
    Are they covered under my warantee ?
    Think relay has gone too as the single wipe dont work unless i hold the stalk on through the whole wipe
    Regular Member jonesy_ni's Avatar
    Co Antrim
    SNAP!!!!!
    Same thing happened to me today, defrosted screen lifted wipers off window to make sure they were not stuck, and would not work for about an hour.
    Had to stay in the house and have more tea and be late for work
    Regular Member Lump's Avatar
    coventry
    and me
    shropshire
    Quote Originally Posted by jonesy_ni View Post
    SNAP!!!!!
    Bet ur boss thought u were makin it up
    May 2007
    south ockendon
    most mornings for the last couple of weeks i have de iced the screen then had to use a squeegee so i can see, ****** wipers dont like working in the cold at 2am
    common problem or a design fault? are they supposed to stop working at around freezing point or below
    May 2008
    London
    Hasnt happened to me, but when it's cold I cannot use the front and rear washers as the water is frozen in the nozzles!!!
    shropshire
    Quote Originally Posted by kktdragon View Post
    Bl00dy vectra's
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    same here
    Nottingham
    Quote Originally Posted by Steven T Davies-Moss View Post
    Same thing has happened to me a number of times over the last month.
    Trying to set out about 5am,and drive to SE, no washers/wipers until o/s temp gets to 0 degree.
    Booked into garage to sort,and they tell me nothing wrong with system.
    Offered to take the car in at 5am on a cold morning but they declined.
    Vauxhall say they have never heard of problem !
    Told my company I cannot safely drive the car when temp is under 0 degrees.
    Cheers,
    Terminator
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The problem is very simple, moisture in the motor freezes and holds the brushes away from the armature winding commutator, thus not making electrical contact and non operation. Next time it does it, pour warm water over the motor (if you can get it in there under the scuttle panel)
    Never had it on mine, and I don't think it is a design feature either.....
    Maybe a motor strip down and rebuild would help, with a slight spray of WD40 or a dab of oil.
  1. Replies: 10
    Last Post: 30th October 2012, 01:28
  2. Auto wipers.. How do they work?
    By cont1204 in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 21:57
  3. windscreen wipers don't work
    By clive3373 in forum General Chat
    Last Post: 7th December 2009, 22:54
  4. Window wipers
    By Q22ube in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2008, 00:42
  5. Intermittent wipers: How do they work?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2006, 18:45
