Thread: 150 cdti with no power
    Norwich
    Default 150 cdti with no power
    Hi There -
    Am the proud owner of an 05 sri which seems to have just developed an intermitent fault. From cold the engine wont rev and the car will barely pull away almost as if I am in top gear - then when above 2000 revs we are back to normal. Could this be fuel starvation or the dreaded swirl valve?
    Any opinions or advice would be greatly appreciated.
    Regular Member cameraman's Avatar
    Leicester
    Mine was like that when the EGR valve was faulty
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    yep egr
    Norwich
    do you think this will be pricey, or maybe still covered under warranty
    Oct 2007
    Gloucester
    Defo the EGR valve.
    It is possible to clean it up yourself if you have some mechanical ability.
    I don't, unfortunately, and it cost £120 or so to change.
    Good luck.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    its always worth just removing it and giving it a good clean first before replacement! its easy enough just take your time.
    Norwich
    great thanks for the advice
    Leicester
    If your car is over 3 years old then you'll be lucky to get it done under warranty, my work mate had the same problem & took his to his local VX dealer they cleaned his EGR as they were on back order & it's been ok since (mine was replaced about 50,000 miles back & still ok)
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    http://www.vectra-c.com/forum/showthread.php?t=64677
    Yep, I'd say the EGR valve. Read the link above and are the symptoms like yours?.
    The much cheaper part is in the link as well verses VX dealers for exactly the same part. VX +£350 :icon_eek
    Regular Member djr69uk's Avatar
    Midlands
    defo clean the valve... it takes about 30 minutes if you are handy with the spanners - and that includes 20 minutes cleaning the valve
  1. No power from 1.9 cdti 150
    By garetmcc79 in forum Engine & Drivetrain
    Last Post: 1st April 2012, 08:04
  2. 1.9 cdti 150 no power
    By baz_cdti_sri_150 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 15:00
  3. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  4. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
  5. V6 CDTi - How much power?
    By Craig Rogers in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2008, 20:31
vectra c cdti no power
