Results 1 to 10 of 18
Thread: Rear Brake Pad Change
    crewe
    confused Rear Brake Pad Change
    I have just changed the rear brake pads on the off-side of my Vectra 2003, 1.8L. No problem, wound in the calliper piston using mole grips. However can't get the near-side piston started despire how many times I turn it. Does anyone know whether the near-side is a left-hand thread.
    cambs
    the thread is the same for both sides
    you should use a rewind tool m8
    using a pair of mole grips
    could do damage to the calipers
    Regular Member poves's Avatar
    lancashire
    But if your happy using moleys , you need to put some force against the piston , to help it on it's way . Well that's what I did anyway whilst turning .
    crewe
    Smile
    Quote Originally Posted by mhvcbv View Post
    Many thanks for that
    crewe
    Smile
    Quote Originally Posted by poves View Post
    Many thanks for that.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    you want one of these fella:
    http://cgi.ebay.co.uk/Brake-Caliper-...71110001r34047
    cheap and chearful and does the job..
    lancashire
    It may be cheap and cheerful but he needs a solution now
    Not in a week lol . It doesn't look that bad though , but to be honest I always rough it
    Middlesex
    Trim : SRI
    Mileage : 100k
    Always available from your local auto factors - thats where I got mine
    scunthorpe
    just done discs and pads mine, take it you clamped the flexi hose and released thebleed valve, i had to extend 1 of mine right out then rewind it as it wouldn't rewind at first.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by paul515 View Post
    You shouldnt touch the bleed nipple unless you are bleeding or changing the brake fluid..
    All you should need to do is remove the cap on the brake fluid resoviour so that the fluid is pushed back into the resoviour when you press the caliper back... Opening the bleed nipple could lead to air in the pipe if you are not under preasure...
  1. rear brake pad change
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 19:46
  2. Brake Pad Change
    By dti owner in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2010, 03:25
  3. rear brake change tomoz
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2010, 19:27
  4. noise since rear brake change
    By magpie27 in forum Handling & Braking
    Last Post: 9th November 2009, 12:17
  5. Rear brake change
    By grumpano in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 21:53
cdti 150 brake brake pad change
