Does the sensor read from the DMF or elsewhere on the crank?
If it is the DMF, where is the sensor pickup located on the DMF itself? I can't see the usual pin on the outer edge, is it the small strip (goldish colour, approximately 30mm long with 3 small ridges on it) that looks kind of like a balance weight stuck to the back (engine side) of the flywheel?
