Thread: Loss of power, Engine Management Light, Spanner Light
    Cheadle
    Default Loss of power, Engine Management Light, Spanner Light
    I've noticed a few posts about this problem albeit a few years back and i'm not sure if there is any surefire solution.
    The problem is the engine management/transmission warning light (the one with the spanner appearing through the car roof). In a higher gear, above approx 3000 revs, this warning light comes on and the car switches to 'safe mode' or limp home mode as it appears to be called on this thread. If i turn the engine off and then restart the light disappears.
    Is there any new insight into the cause of this fault or an quick remedy as it appears to be something that is realatively common.
    Regards
    Shadrack
    13 Post(s)
    You need to get the fault code(s) read out. Takes away all the guesswork of what is wrong, which could be any number of things.
    Cheadle
    I understoood that the fault could only be read whilst the light is on?
    As the light disappears when the engine is restarted this could make things difficult. I know you could get the read out yourself on earlier Vectra models. Is this possible on C models?
    A mechanic kindly tested it for me for free the first time the power loss occurred but found nothing. Clearly this was no extensive check and at the time I took it as evidence of a temporary blip as indeed the Vauxhall Vectra User Manual implies. Needless to say the fault has happened too many times for this to be a 'one-off'.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Code is stored in memory. The light coming on then going off indicates there is a code in memory. So you can still get the code read without the need for the light to be on
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    As above mate could be any thing from egr valve ,boost sensor,s vacuum actuattors , split hoses ,etc .
    Get the car tech 2 ed at a vx dealer , then record what the fault codes are that have been thrown up from there we should be able to steer you in the right direction
    and still loving it
    Cheadle
    Thanks all, for all your help.
    Oct 2012
    Doncaster
    Hi mate I've got same problem I've already spent a fortune on car only way to find out what problem is.is to take it to vx dealer the small or DIY code readers don't work vx dealer is gonna charge £79.95 to find problem it's worth to find problem I'd say
  1. Replies: 17
    Last Post: 16th August 2012, 10:07
  2. Spanner Light and Engine Management Light
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 13:42
  3. Idle problem, loss of power, engine management light on.
    By Coyney in forum Engine & Drivetrain
    Last Post: 10th July 2011, 10:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
vauxhall insignia engine management light on
engine light on vectra c and loss of power
2009 vauxhall insignia loss of power and engine management light
spanners through the roof light
vetrca 1.8 what cause lose power
