Thread: Whinning belt
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default Whinning belt
    hi all
    got a new one for me anyway.
    just serviced the siggy oil, fuel and air changes were made.
    But now noticed when its a cold start and you accelerate i hear this whinning noise coming from the belt? is this common?
    May 2008
    London
    Yeah, for me on my vectra C 2.2 dti 2002, some bad whining from the drive belt. Happens every morning or when it's really cold, full turn, reversing etc.
    I changed it the other day using the haynes manual and it all went away, less stuttering too on first start.
    Got a replacement belt for about a tenner.
    Nov 2007
    Leeds
    whats the belt called...sorry to sound thick not been that end of the engine before!!!
    how long did it take to replace?
    May 2008
    London
    It's the 'Auxiliary Drive Belt', you could find some on fleebay. not sure exactly where it is on your engine, but when you do order one, make sure you get the right one, with/with out air con.
    Mine was located under the air box, had to remove this and my driver side wheel to get access.
    May 2008
    London
    for me being a bit slow, about an hour, had some trouble putting the belt on because I couldnt loosen it and slip it on at the same time. Called my bro to help in which he just slipped it on while I held the tensioner to slacken/tighten it
    Nov 2007
    Leeds
    im going to have to get a haynes me thinks....!
    cheers for this info though ill give it a shot on the weekend
  1. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  2. whinning vectra!
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 17:41
  3. High pitched whinning noise.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2008, 16:00
  4. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
  5. fan belt ??
    By arniedavo in forum Engine & Drivetrain
    Last Post: 10th September 2008, 01:16
