Thread: Expensive Noise?
    Jan 2006
    Bedfordshire
    Default Expensive Noise?
    Hi All.
    My CDTI 150 Auto is making a loud swishing noise when started from cold- disappears after car is driven and warms up. Any ideas at all, I'm wondering about a bearing somewhere...
    Also, car has now done c72,000 miles. Anyone know how far these engines usually go without major problems? It's had the usual EGR work done.
    Thanks again for any help
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like mine does in the morning i think its just the turbo
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    This may sound daft - but is it like a wooooooo noise!! lol?? Almost like the start of a police car siren or something?? But when the turbo actually boosts slightly further up the rev range (goes into positive preasue) it goes and you get the standard sucking noise?
    If so its where the Turbo bearings are cold and they make this noise, quite normal for a turbo to do that- its quite a small compressor also on the CDTI's.
    My previous Saab 9000 ran a large Turbo, and peaked at 1.8 bar preasure, and this too did the same - only slightly louder than my CDTI..
    Leicester
    The water pumps can be very noisy when cold until they are warmed up on high mileage cars. Although there is no specific time scale for changing the water pump, I have been advised by Vauxhall technical that they should be looked at with a review to renewing at about 60,000 miles. If the bearing goes, it will take out the came balt.
    But this is not the end of the world on the 1.9 CDTi 150, if the belt goes, normally you just brake a few rockers and not destroy the engine.
    Maida Vale
    Quote Originally Posted by Maverick View Post
    Break a few rockers? I nominate Rod Stewart - annoying wrinkly git that he is.
    lol
    Leicester
    Quote Originally Posted by Thomas1 View Post
    lol
    lol at that one!
    Nicking Ya Dinner.
    Try filling the tank, on my Skoda it makes this noise when the tank is low or no more than half full, what it actually is is the fuel pump priming itself, not sure if it's the same on a CDTi, but it's the cheapest rule out I can think of before you look for other things.
    Jan 2006
    Bedfordshire
    Thanks all. Defo not a "woo" noise- more a swish. I think the water pump is most likely
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    mines got a silly loud turbo (sounds like police car) the ammount of friends that thought they heard police behind me when driving, still boosts fine still
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    quite loud noises of this kind are usually a loose or split boost hose or as a friend had a small hole in the intercooler rad! mine is not noisey at all except feint boost a whistle from the turbo.
  1. This is getting expensive
    By blackbeauty in forum Styling
    Last Post: 2nd October 2011, 22:37
  2. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  3. WOW!! now that does seem expensive!!
    By actionman in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 19:32
  4. Most expensive re-map!!!
    By mushy2007 in forum Engine & Drivetrain
    Last Post: 10th March 2009, 23:46
  5. The most expensive car....
    By blr123 in forum Detailing and Car Care Discussion
    Last Post: 4th April 2007, 09:12
