Thread: Emergency plumbing question
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default Emergency plumbing question
    A rad has corroded and starting squirting water everywhere.
    Its now a second spare room and not needed to be heated,
    Ive isolated rad at either end and so far has stopped the leak, question is ;
    A; Will this mess with the other rads ballancing,
    B; Cure the leak till i buy a new rad (dont want to awake to find a new swimming pool ((as much as id love one)))
    Im an electrician not a plumber at the end of the day lol
    King status will be awarded to the person with quickest CORRECT answer.
    lol
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Pretty sure you'll be OK - I've run a system with rads completely removed for maintenance / decorating. It depends on your set up of course.....
    Mind you, I'm not a plumber either - now back into the loft to check on my ongoing seeping joint ( ooh err missus... ) caused by a plumber choosing an easy option
    cambs
    hi
    no it shouldn't effect the other rads as they are spured of the main flow.
    if in dought just put the heating on and check the rads are warm.
    Full Member Big Sig's Avatar
    A) no it shouldn't mess with them
    B) as long as the valves hold
    Regular Member Hs2300's Avatar
    yorkshire
    you'll be fine fella, as long as the taps seal it wont leak or effect the other rads in the house.
    Regular Member Jeff Lynne's Avatar
    England
    I'd also check at some point your system has enough corrosion inhibitor in it
    Regular Member ade0303's Avatar
    GET OUT!!!!! It's gonna blow!!!!!! errr... I mean it'll be fine...
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    as above matey, it will be fine as long as the valves are propperly off (if therm valve make sure it is off as far as it will go) and when you fit the new rad make sure to put inhibitor in it, you can buy fernox in a tube that inject's through the bleed hole, if you are on a combi boiler you will need to re-pressureize the system by the filling loop under the boiler, if gravity fed then it will self fill from a small header tank in the loft, make sure you bleed all the air out of the rad, and also check the rest of the upstair's one's also
    Midlands Mod Shop - NFFC.
    cheers folks, seems to have held for last few hours, even put pump on full duty and it still held, i thinks the house is upset cos we put it on the market lol,
  1. plumbing question - ball cocks
    By Caveman_nige in forum The 'Off Topic' room
    Last Post: 6th November 2012, 20:03
  2. Plumbing advice needed.
    By chrissri82 in forum General Chat
    Last Post: 6th December 2011, 13:56
  3. Plumbing Advice Needed..
    By Jezzy in forum The 'Off Topic' room
    Last Post: 6th December 2009, 22:24
  4. Small Plumbing Question
    By Damian in forum General Chat
    Last Post: 15th May 2008, 19:52
  5. plumbing advice
    By John35 in forum General Chat
    Last Post: 20th August 2007, 22:02
