Thread: Washer pump removal....
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Washer pump removal....
    Is it a bumper off job? Still having problems with the washer jets seen more power in a dripping tap,jets have been cleaned,blown out.
    Regular Member scottyd's Avatar
    paisley
    do a quick search on the site mate loadsa threads on this subject
    Sunny Dartmoor
    You remove near side wheel arch and can gain access that way,good luck......
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    is it that bad?
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    Yep wheel off, liner can just be pulled forward, get the little pump off and clean all the 'jellyfied gunk' off the little filter on the pump.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    did it earlier thanks for the replies,managed it with th wheel still on just took the 3 torques out in the arch liner,hence my shredded hands,tiz like a power shower now!!!!
    Regular Member sy_uk's Avatar
    Newcastle
    how can i get the bottom screw out? My torx screwdriver is just turning in the head
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    i used a small pair of long nosed mole grips,it did the trick of me as it was rusted up from all the road crud
    Newcastle
    cheers mate, will try that
    member of the smoke patrol 230bhp+
    i bet its the rubber in the washer bottle not the pipe thats getting blocked up
  1. Washer/pump/dohh!
    By nikroc in forum The 'Off Topic' room
    Last Post: 18th January 2011, 20:03
  2. Washer Pump
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 13:29
  3. washer pump
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 15:37
  4. screen washer pump
    By simon1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2008, 16:40
vectra c washer pump replacement
vectra washer removal
vectra c washer pump removal
signum washer pump removal
vectra c washer jet motor location
