Thread: electric gremlins
    Jun 2007
    Black Country
    Default electric gremlins
    Ive just noticed that when i use the wash jets at the rear, the fronts squirt water too, they have never done this before. Ive stopped the engine and tried again 10 mins later and now the fronts foam a little but dont squirt, unless i use the fronts.
    Any ideas?
    Ive also disconnected the heated front jets to test they are getting voltage, they did for 2 secs then nothing atall, ive checked the fuses next to the battery and found that fuse 8 had blown (10A). But fuse 8 is listed as headlights in my handbook and nothing to do with the heated screen, since replacing the fuse, i can hear a tiny click at the rear of the car when i switch the heated screen on/off
    could this just be down to the cold weather causing problems ?
    Regular Member scottyd's Avatar
    paisley
    or a cim failure or maybe a faulty ind stalk
    Regular Member stuee's Avatar
    witney near oxford ish
    weird shouldnt be down to the cold weather as the heated rear screen is designed to de-mist and de-frost so temp shouldnt be a problem. but possibly u may have faulty elements. as 4 the washers that sound kinda cool that u can clean both windows at the same time lol
    Jun 2007
    Black Country
    After fitting a new fuse, the wipers seem fine, cant understand why they should be connected to the No8 fuse though
    also the heated mirrors get way to hot, ended up with a blister on my finger from touching the mirror when it had been on for 10 mins
  1. Electric Gremlins
    By woody in shetland in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2012, 21:39
  2. Gremlins/help
    By s2yob in forum Engine & Drivetrain
    Last Post: 7th November 2011, 22:42
  3. Electric mirror gremlins!!
    By Pecojess in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2009, 18:36
  4. Electric Gremlins are sorted....
    By Signum_CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2008, 21:52
  5. Gremlins
    By david173 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2006, 10:32
