Thread: EGR valve / Swirl valve
    Regular Member SwavGav85's Avatar
    Inverness
    Default EGR valve / Swirl valve
    Is the EGR valve the same thing as a swirl valve?
    Think mine is pooped!
    Any advice would be great!
    Inverness
    confused
    Oh i for got to say my EGR valve has gone after only 20563 miles!
    Administrator plasma's Avatar
    On the Forum
    577 Post(s)
    Engine : 150
    Mileage : 74000
    2 totally different things mate, EGR makes the can reburn exhaust gases, and a swirl valve opens up a 2nd set of pathways to the air intake chamber. thus altering the swirl pattern of the air i believe...
    Inverness
    Do the swirl valves play up much??
    Quote Originally Posted by SwavGav85 View Post
    Yes
    On the Forum
    577 Post(s)
    Engine : 150
    Mileage : 74000
    yes, they become coked up become sticky, you can also see them 'lift' slightly which is why you get oily deposits around them, and the bar which connects them altogether likes to fall off too!, 2 options cheapo £1 rubber wash fix (may/maynot last depending if the valves jam up) and the other option is complete new inlet manifold with swirl valve
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    im looking to clean the egr on my dti signum....do i need any sort of gasket or replacement parts when refitting or is it a straight remove clean and refit?
    Chesterfield
    Assuming it's the Y20DTH engine with the electric EGR, (I don't know anything about Signums), it's sealed by an O-ring. You may get away with it but the VX part number is 93172881.
  1. Swirl Valve bar has come off
    By coooky in forum Engine & Drivetrain
    Last Post: 27th January 2014, 11:57
  2. Egr valve, swirl valve problems etc..
  3. swirl valve
    By vectra_lover09 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th July 2009, 13:09
  4. Swirl Valve...
    By teilo in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2008, 23:09
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
