Thread: Pink Antifreeze
    Mileage : 000
    Default Pink Antifreeze
    Could anyone refresh my memory. The VX Pink long life Antifreeze. Is it best to replace it after 3 years or is it 5 years. I forget.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    it has a 5 year life span
    Belfast
    Just the way air filters are 4 years.
    I'd do it every 2 years to be sure of it. It's cheaper than a busted radiator.
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    changing the long life antifreeze every 2 years defeats the reason to having long life antireeze
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    you can always test it, if you have the right gear?
    Regular Member danlat1415's Avatar
    Lancashire
    I'm thinking of changing mine too.
    Where's the bit you take off to release it all? is it at the bottom grill next to the radiator?
    Also, roughtly how much does it take to refill?
    Mileage : 000
    Quote Originally Posted by PeterVV View Post
    I do have an anti-freeze tester. I will give it a go tomorrow and see what strenght it is.
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by ed taylor View Post
    be carefull as the longlife antifreeze gives a different reading to the normal antifreeze,there is a proper tester for this antifreeze
    Belfast
    But you only have long-life because they put it in in the factory. Same as fully synthetic oil, and the wrong size rubbish tyres and brake pads made out of wood.
    £15 worth of antifreeze every 2 years is better than a new radiator in 3.5 years, isn't it?
    Mileage : 000
    Quote Originally Posted by _ZS_ View Post
    You do have a point, I must admit. New is better than old. So to speak. I was told many years ago that "old" anti-freeze can ruin the head gasket?????
  1. Pink Antifreeze texture
    By VVT-i-MATT in forum Engine & Drivetrain
    Last Post: 20th March 2012, 20:11
  2. Antifreeze
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 23:21
  3. AntiFreeze
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2011, 14:18
  4. antifreeze
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 18:46
  5. Antifreeze
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 19:38
vectra c pink long life coolant
