Results 1 to 10 of 27
Thread: H.i.d's help..
    Regular Member alexander08's Avatar
    derry
    Default H.i.d's help..
    right i just bought h7 8000k h.i.d's .. will these definitely fit my 03 vectra club? ? sorry if this has been covered.. thanks for any help.. and are there any how to's or should i just get them fitted professionally..??
    Regular Member cornishpirate's Avatar
    Cornwall
    loads of posts about these m8
    lots of info about fitting and also potential problems with bulb failure light, etc,
    do a quick search and you will find
    derry
    aye i know i tried searching but can't find what i want answered.. i just want to know if h7 will fit my vectra.. its an 03 vectra club.. and what are the cancelers that people talk about.. do i have to buy these separate?? i've tried google and everything.. not very good a searching ..so any help wouldbe appreciated.. thanks..
    Cornwall
    H7's should fit the low beam and I think you will need H1's for the main beam
    I think the 'cancellers' are the bits that stop you getting problems with bulb failure warnings when your ecu doesn't recognise the hid's as operational bulbs.
    I know that the more expensive kits (M-Tec, HID's Direct) come with all of the bits you need but I don't know if you can buy them as separate items.
    hope this helps
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Quote Originally Posted by cornishpirate View Post
    Pre facelift are H7's for dipped and Main
    derry
    awright thanks for your help.. i bought it off someone local you see because he got h7 sent out by mistake which wouldn't fit his vectra.. it says savage car styling on the front of the box..
    Cornwall
    Quote Originally Posted by Waterboy View Post
    thanks for clarifiying that - couldn't remember what was in our old car
    derry
    was told there that if i have a club which doesn't have the mpg display etc... i wouldn't need the cancelers??
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    You will still need the cancellers as there is a warning display in the rev counter.
    The lights will also pulse and flicker without the cancellers.
    derry
    ahh you serious.. can i buy the cancelers separate? don't think they came in the kit..
